Battery Issues
cbailey3160
Christopher
El Cajon
Does anyone else’s Bronco make noises when you’re around it? I mean when you don’t have your keys in your pocket. I keep on getting notifications that remote services are disabled because of the battery. Granted I have rockslide engineering sliders on it, a winch, which is interrupted by a disconnect, and a mouse blocker. I put the interrupter on the winch, thinking it was the winch draining the battery. It seems to make almost the door, locking unlocking sound intermittently throughout the day. If anybody can point me in the right direction it would be appreciated.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
My Bronco make all kinds of noises after it's shut down...some happen quite a while after.
I to have a winch, multiple lights, added rear power for my compressor and 2 way radio wired through the upfitter switches with no issues.
Have you drained the battery, if so, you need to charge it, driving might not be enough to fully charge.
dgorsett
colorado
F250, Mustang, Explorer
Yep mine makes funny humming and clicking sounds kinda randomly. We recently got a 23 Explorer with more bells and whistles and it's ridiculous when you get around it with a key, clicking and clacking, that might be the proximity lock/unlock arming???
thesocalexplorer
Southern California
My bronco doesn't have the proximity key, so I don't get noises as I walk close to it. But once I open the driver's door or push in the clutch, I get the robotic wastegate sound along with the fans in the headlights spooling up. It's my sign that she's ready to rock haha.
What's your resting battery voltage? Definitely seems like there may be some parasitic draw somewhere possibly.
DUSTYcazOREGON
Craig
Some of the noises you hear may be downloads and communication with Ford and your App.
As far as the battery; these new vehicles are never off, something is always running. I keep mine plugged in 24/7 to a Deltran Battery Tender (all of my vehicles). Unplug and go! It is always ready, battery topped off and it lengthens the life of the battery.
Ford Bronco Battery Issues BT1
RHeinz
Ric
Houston, TX
How does the “mouse blocker” function? Is it generating any RFI which might be interfering with the Bronco electronics and keeping it awake at night?
EDIT: Is it connected directly to the Bronco battery? Or an external 120 VAC power supply? If it’s connected directly to the Bronco battery, what is its amp rotating?
cbailey3160
cbailey3160
Christopher
El Cajon
After two years of owning it, last week was the only time I ever had to put a jump box on it. I was hoping somebody else could tell me. Yes, the AGM battery is bad. I’ve got the extended warranty. I’m gonna see what the dealer has to say.
To my knowledge it only generates a higher frequency “song”(I don’t hear it but others can) and lights. It was a recent addition and I doubt it is the issue. I contacted Ford yesterday to no surprise the battery is not a warrany item, even with the extended warrant. Something to note the replacement battery is on back order.
RHeinz
Ric
Houston, TX
The same exact AGM battery in my wife’s Lincoln Nautilus started doing funky things when it was a little over two years old. She couldn’t use her iPhone “ford pass equivalent” to start it and it showed strange voltages when charging. I replaced it and she has had no further issues.
cbailey3160
cbailey3160
Christopher
El Cajon
That’s my issue to the date. Batteries two years old. I’m going to replace it when they become available.
helifino16
Ron
Mount Sinai, NY (Long Island)
I just think my Bronco is 'purring' at me like an affectionate cat. "Let's go for a ride!"
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
If I don't run mine much for a week I'll put a smart-charger on it until I get the battery 100% charged.
When I close the hood after the charge... it always makes a click or two.... always!!!
I assume that is just R2D2 telling me -- "thanks for the meal -- I'm full"
jrollo7
James
NY
Range Rover Sport
I don’t have any special lighting, etc but yes, sometimes walking around my ‘23 BD Bronco I hear tick like sounds or switch like sounds. Weird. Listening to us-like our phones?!
flip
Phil
IN
www.ruxerparts.com
Fords
We have a bronco customer with a battery draw caused by the rock slide steps. Have had to drag it in twice, charge and return. Told him to either call rock slide and get a replacement module, disconnect them or keep a battery tender on it since it's not daily driven. He has not made any mention of wake up or power down noises but once battery voltage drops below a set limit modules start freaking out and do dumb stuff.
JT58Bronc
JT
Fl
Mine makes a clicking noise under the dash after I unlock it and sit in it with the key on me. It takes about 5 minutes or so after I unlock it and it makes the clicking sound. The reason I know is at lunch time at work I sometimes I go into the Bronco and sit the back and read for 20 minutes or so. It does this every time and sometimes startles me as the clicking noise is quite loud. I don't know if it does this because the key is in it and it's maybe not started? When it's in the garage just parked and no key in it, it makes so sounds at all. I am in the garage a lot working on projects so if it made any noises I would hear it.
