Battery Drain issues
J2D
J2D
Matt
Alabama
www.instagram.com
2021 Bronco, 2004 Mustang GT, 2021 Expedition
It appears as those three weeks is the secret number for me. I had an alert again about the battery drain and the only commonality I can point to is the fact that I haven't driven the Bronco in roughly three weeks.
stdevore
Suzanne
MT
My Raptor that I have only had for 6 months was dying if I didn't drive it every day. Finally was able to start it & drive it to the dealership. They said it would be at least a week. $90K gets you lots of headaches!
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
There's a new SSM related to battery drain issues take a look at you door locks just in case.
Ford Bronco {thread} {filename}
SSM 52258 2021-2024 Bronco - Parasitic Battery Draw
Some 2021-2024 Bronco vehicles may exhibit a parasitic battery draw. This may be due to an interior door lock switch on the driver's and passenger's interior door panels. Prior to normal Workshop Manual (WSM) diagnostics, check both front door lock control switches for damage and/or proper operation. If a front door lock control switch does not operate as designed, repair as necessary. If no problems are found, continue with normal WSM diagnostics. For claiming, use causal part 14028 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual. If the draw is still present, refer to WSM Section 414-00 for normal diagnostics.
tkgeyer
Thomas
Vancouver
2015 Mustang GT
Did you get this resolved with yours? My Raptor is doing the same thing. Appointment on Tuesday to take it in. Going to reference the SSM below to them just in case it’s overlooked.
APEX REX
23 Braptor and 21 2D Base 2.7 SAS
My local dealership just picked up my 23 Braptor with 800 miles on the ODO. I'm on my 3rd battery. I figured it was just a bad factory battery after the 1st time, but it did the same thing again after 7 days of non-use the 2nd time so definitely some form of drain. After the 2nd battery replacement, I put in on a tender and it was down to 80% after 48 hours from being fully charged. Zero mods. I will report back once diagnosed.
As a side note, my 21 2-door SAS is running like a champ, zero issues.
BadBradBronco
Brad
South Florida
2015 Explorer
Hello everyone. 22 OB Non SAS here. Ice Mountain survivor Jan - Mar 2022. Now having this same weird battery issue. Seeing a lot of the same messages regarding deep sleep, System off to save battery etc…daily driver so it’s not sitting for long periods. Maybe 2-3 days tops over a weekend. Battery is testing fine, no issues. Other thing Ive noticed is the auto start/stop has been disabled for a couple of weeks now. I know this is usually a precaution when battery is low. Any other updates on what I should be looking for or doing to resolve before taking in for service?
nomnom
Alan
Colorado Springs, CO
2021 Basequatch
Adding to this thread, my 21 4 door base Sasquatch died while on trail Saturday morning. 2.5 hours later flagged a park ranger who came to jump it, had to stay hooked up for a full 5 minutes before it would start. Car functioned normal the rest of the day.
wake up Sunday, completely dead battery. Jumped again, drove straight to autozone and swapped with new battery.
woke up Monday (today), dead again. Currently sitting at the dealer, they’re trying to blame my lights/winch even though all that stuff has been on the car for over a year. Somehow it killed a brand new battery overnight.
they even tested my old battery that I brought in and said it’s still very good.
alexryer
Alex
Winchester, MA
2021 Bronco Black Diamond 4-Dr Soft Manual
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
VIN:1FMEE5DH6MLB08496 Bonnell Motors in Winchester, MA.
Have same parasitic drain problem - battery dead after several days not driven. Dealer replaced battery on 9/8/2024 service visit. They noted accessory ditch lights as possible cause (they are all connected through prewired upfitter swiches and hadn't been used) - not a cause. Also the doors had been off for weeks, so wasn't door locks.
The dealer is clueless. Need assistance.
Thanks,
Alex
