Base bronco 2dr tire upgrade suggestions
I'll argue that 1/2 tons routinely run SL tires and the ones that run LT are for carrying far more weight than a Bronco could ever consider, even if it wanted to. There just isn't the room for a load of dirt or bricks or plywood, etc etc etc.
I'll also argue the weights you mention could easily be an extremely loaded Bronco vs an empty truck. IE, the Bronco won't get any heavier than that, whereas the truck will get substantially heavier once loaded.
The number one reason for LT preference on anything less than a full size truck ... jeep, Taco, Bronco, Ranger etc ... will be puncture resistance.
Beyond that, LT rated tires bring mostly negative aspects to the bargaining table for lighter duty vehicles, ESPECIALLY E rated tires.
That being said, many folks have run LR E tires on Jeeps and Broncos and have been thrilled with the performance.
I am not a fan.
Your mileage may vary. Lol!
Fwiw, the Firestones did really well in tests and reviews. Solid choice for the usage you mention.
I would consider SL tires too if I could find them in the sizes I want to buy.
kodiakisland
Arkansas
Love 255s and ran those until I went to 35x11.50 and then 37X11.50. Skinny has a lot of performance,
JonB2
JonB2
Jon
North Hollywood, CA
2025 Ford Bronco 2-door
Back to OP's original question, and some info about your set up and options as well.
I ran Toyo 35 x 11.5-17 on my Base 2dr manual (4.46 & 2.3L).
They looked awesome and fit well with Method wheels +35mm.
Link below.
I took them off because the tires could not be driven in the winter and I kind of liked the 30" Base look again for a bit there.
I'm over that now and will be going back to a taller tire in the fall/winter.
After my bad rubber experience, no help from Toyo and YEARS of research, the only two (BIGGER) tires I would consider are:
Nokian nAT 285/75-17
Mickey Thompson 255/85-17
Tirereviews.com did winter testing with a group of AT's and the Nokians and MT's did REALLY well.
Jumping back down to a 285/70 in SL,
I'd be all over the MT's or Nokians again, but there are a LOT of great SL rated 33 inch tires and a lot of very good reasons to choose the SL rating for the Bronco.
After my issues with the Toyo's, cold/wet/winter traction has become my #1 priority.
Almost all tires do good enough in the dry, but when conditions change for the worse, that is when you are forced to rely on good rubber.
https://www.bronco6g.com/forum/thre...no-lift-method-703s-toyo-35-x-11-5-17s.32232/
My 35x11.5-17's .... no lift, base suspension
Curious if you had SL rated tires and then noticed a difference running load range C as far as noise or stiffer on road ride? 285/70/17 available in SL and C, but the 285/75/17 only available in load range C and up.
Philvis77
Phil
2000 Jeep Cherokee
For my stock 2 dr Badlands (285 70R17), I just changed to Falken Wildpeak AT4. I think they look great and love them compared to my K02's which i absolutely hated due to not being good in wet conditions. I had to order the smallest bumpers (i think from Sasquatch) for my tailgate as the spare wouldn't go on with the stock Badlands bumpers.
lakesinai
Charleston SC
Hello--must of looked through hundreds of posts but can't make a decision and need a little help. Here's my current Bronco setup:
OEM wheels off a Ranger 17" +55 offset
Firestone 265/70/17 Destination AT2 (very good tire so far)
Looking for a more aggressive and taller tire keeping same wheels. Want to fill out the wheel well better and gain some ground clearance.
Priorities are 95% on road use/commuting daily driver, 5% dirt/fire roads/light offroad--so tIre noise and comfort more important than heavy offroad ability.
Possible sizes: 285/70/17 or 285/75/17. No lift (yet).
Tires: BFG KO3, Nitto Terra Grappler G3, Toyo Open Country ATIII
Please give me your opinion as to which size might look the best as well as which tire you may recommend.
Thank You! Appreciate any suggestions before I make a final choice.
The nicest tire upsize without breaking the bank or needing modification is what I've had on my non-SAS OBX for 3 years: 17x8 Badlands Take-offs wheels with a 285/70R17 tire, "33's, which adds almost an inch of height. A nice road/trail tire is Nitto Nomad Grappler (i have, photo below) or perhaps Nitto's new G3.
My Nomad Grapplers are wearing out, so I'm going with Micky Thompson AT on some take-off Heritage Sasquatch wheels, 17x8.5. Then a mild coilover lift in my 5th year. The OEM Hitachi are getting rough, time for an upgrade. The advantage of the takeoffs is they fit as OEM wheels, and the price is right as Take-offs ($100-125 per wheel cash). I always go pickup in person, cash only.
Ford Bronco Base bronco 2dr tire upgrade suggestions 20260514_140615
HoosierDaddy
__ Eric
NW. Indiana
The 35 x11.5-17 were C rated. I'd say they rode fine, and I'm rather picky about tire performance.
Really , my only beef with them was the rubber compound.
I'm dead certain I was sold a bad batch and Toyo did fuck all nothing to help out. Never returned a single response.
This is why I strongly encourage folks to find a trusted local tire dealer in the event something like this happens.
I mailed ordered from Summit, not much they could do after the sale ... take them to a local Toyo dealer, who will not be thrilled to help you on tires you cut his throat on by going mail order.
Live and learn.
JonB2
JonB2
Jon
North Hollywood, CA
Thanks all for the responses! Going out this week to look at some more tire options. I'm thinking a load range SL or at most C would fit my needs of priority onroad ride. Narrowed it down to either 285/70 or 285/75. 285/70 has the option of SL, but I just like the looks of 285/75 better what can I say.
And to add one item--I want to fill out the wheel well visually. Will a small wheel spacer help to improve that? I read that it makes the wheel opening appear smaller. If so, might go with 285/70 + wheel spacer. Just a thought. Thanks.
Jason519
Jason
Alabama
F150 4x4
That looks great. How's the ride quality and noise, especially on the highway?
I can’t tell any difference on the ride and not much difference in noise either I did remove the crash bars before the tires. I have put a 2 inch spacer lift in front and 1 in the back looks better without the lift of your not doing much off roading I wouldn’t worry about any lift it will look good without it
That looks great. How's the ride quality and noise, especially on the highway?photos after the lift
Ford Bronco Base bronco 2dr tire upgrade suggestions IMG_1362
Ford Bronco Base bronco 2dr tire upgrade suggestions IMG_1363
JonB2
JonB2
Jon
North Hollywood, CA
Did you feel the need to regear or does it still pull and shift ok with the larger tires 285/75/17 ? Thanks!
JonB2
JonB2
Jon
North Hollywood, CA
Well I finally decided--LT285/75/17 (load C) it is. Looks a lot better. Now I had stockish tires before and to be honest these LT tires do ride firmer and you can really feel the road with these tires, especially on rough pavement. Maybe too much. Not an uncomfortable ride but it is definitely firmer like a sports car. Better handling and less brake dive though which is good. Took it offroad hard pack dirt and ruts and it is rough. It may be the stock Hitachi shocks. but going slow I was dipping back and forth in the ruts and the hits were harder than before with the nonLT tires. Currently at 34psi cold.
Maybe that's just the way it is and if so then fine. Otherwise, not sure if it's a tire thing or maybe I need to change out the suspension or maybe I just need to get used to it. Looking for a smoother on road ride since daily driver 95%/offroad 5% use.
Any suggestions or advise especially those with the base suspension who switched to larger LT tires greatly appreciated. Thanks!
Ford Bronco Base bronco 2dr tire upgrade suggestions 20260625_100934
Jason519
Jason
Alabama
F150 4x4
lol I missed this message lol looks great!!!!👍
Jason519
Jason
Alabama
F150 4x4
Yeah and if you do washboard roads or hard surfaces air down to like 20 psi
