Looking for tire suggestions
FTBronco9
F-150
The ride and drive of the Bronco was improved. Much less "sway" when going around corners. Feels very planted. I'm guessing it's because of the nice thick sidewall.
After a summer of trail driving, I have a lot of confidence in the tires when going out as far as I do alone.
Hope this helps!
Yeah for sure. Thanks. Just watched your video. Good content. Subscribed. 👍🏽
DefNotBuddyLee
Austin
Mustang / Jeep / F150
Hope this helps!
Interesting. I had heard mixed about the Toyos. I almost bought them as well figuring the D load range would beef up the sidewall but I have seen alot of people complaining that the sidewalls were pretty weak on them (mostly Tacos and 4 Runners). The only people I real life knew that had them really didn''t wheel with them so had no insight to give.
I guess that is the problem with the internet, you can typically find something showing either point of view. Kinda wish I had tried them now.
I have heard some good feedback on the MT Baja Boss and BF Goodrich HD Terrain, but dang they are heavy. I do too much off camber to have an extra 20lbs of tire hanging in the air.
B Miller
Sherwood, OR
Interesting. If you’ve seen any of my adventure videos, you would see they have been through the ringer and have never had a problem. Even at the 30psi air down pressure (not that low)
All those other tires you mentioned are excellent as well!
DefNotBuddyLee
Austin
@B Miller I mostly watch your OnlyFans stuff, but I have also caught your YouTube channel. I just didn't catch that you were running the Toyos.
It did get me thinking that I was probably not comparing Apples to Apples. I am wondering if the people who complained about soft sidewalls and trail damage may have been running the C load tires. Regardless, glad to hear they are a solid option because that may be my next tire.
B Miller
Sherwood, OR
😂 My OnlyFans is famous! I bet you're right. The "D" rated tire is unique for that line of tire.
