Phil_Is_My_Middle_Name
Phil
Pinckney MI
20MY F150
Also ask them the angles of the badlands 33. How much better are the rubicon angles?
I think these angles may already be documented on Youtube within a tech reveal? I am going to look for them again.....If not I will ask as well?
truth2ak
Patrick
Alaska
mccoys2nativealaska.net
But they do realize people will add 35's and even 37's to the 2.3 manual setup, right? People also expect the engine tune for the 2.3 to be available in 2021 (or it better be available).
I'm guessing it would void any warrantee on any problems that could be construed as resulting from that modification.
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
i believe you still have the option of not doing the Sasquatch package and getting the V6 engine. Tell me if I’m wrong but that’s what I plan on doing. No Sasquatch and get the V6 instead of the Manual.
Phil
Pinckney MI
20MY F150
So all you experienced owners of 33
No you are correct you just get the Auto Trans. We are talking 23L/Manual max tire size from factory.
Squatch
i want the manual and 35s, so it's Badlands and the 2.3L and I'm okay with that, but it's a shame Mr. Beancounter doesn't think we need that combo from the factory.
BAUS67
redneck
Central PA
Good question. I had thought high clearance meant "small lift" to clear the 35s....and "Special suspension" was the disconnecting sway bars.
So, are we certain the Badlands has the entire Squatch suspension????
I asked @TeocaliMG about this.. control arms different...... but his response was unclear, he said about the HOSS bilsteins are the same but didn't mention about the arms.
I think the high clearance squatch package and the Badlands control arms are the same but I seem to be having a hard time getting conformation of that.
look at how this is........ in the chart next to the HOSS system how at badlands has a line trough it and says standard on the bilstein line but look at the lower models it says hoss system standard but the bilsteins are with the squatch.
Ford Bronco Badlands vs. BadSquatch (Badlands + Sasquatch) Comparison Chart 1595550165127
The only thing I see "special" in the badlands suspension is the sway bar disconnect.
BAUS67
redneck
Central PA
If the oem badlands had suspension to clear the 35's but were given the 33 to separate it from the sasquatch pack. After all the 33's match the oem Rubicon tires.
It was given the 33's because the 35's will rub because of the sway bar disconnect. you can get the 35's on badlands but the suspension is then limited to prevent rub. This is just the way I see it, I could be wrong.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
The BL trim does have the option for High Clearance, but.... It has all the hardware of the Sasquatch package.
Ford Bronco Badlands vs. BadSquatch (Badlands + Sasquatch) Comparison Chart BL Spec - HCS
Ford Bronco Badlands vs. BadSquatch (Badlands + Sasquatch) Comparison Chart BL vs WT suspension
BAUS67
redneck
Central PA
Mike Levin said it was the same coilovers. We also know its the same lockers and differentials. Why would Ford build there supposed Rubicon competitor to be less than the wild tracks?
Because silly rabbit Broncos are BETTER than Wranglers.
/s
Richtor
Sonoma County
20 Tremor 7.3, 21 Badlands Sasquatch Stick(order)
It better not! Ford was displaying all over on reveal day galavanting about with 7sp and 37’s!
Why I posted a thread about it. Talk about class action lawsuit if Ford does deny warranty.
