Base sasquatch vs badlands
freebob
bob
michigan
2022 bronco
Looking at a base sasquatch or a standard badlands for 2026 .Is one better than the other?
MNBigfoot
MN
Pretty equal, if you get the auto transmission, the non-sas Badlands has 4.46 gearing instead of 4.7. So the Base Sas would have slightly better gearing for 35's. With the Manual trans, it's the same gearing. The Base Sas wheels have a different off-set for 35's, and wider fender flares to match.
HalfmuleFarmer
Thomas
2025 Badlands
The Badlands has more out of the box trail armor, if that’s important. And Badlands can be also be had with more options, like the lux package, MGV seats, painted roof, Hoss 3.0, etc, but now you’re getting spendy.
Aknobronco
Ak
Gulf States
F150 F350 Wrangler Taurus Mustang Camaro Cmax
Google is your best friend. Even better now AI can help what you cannot do.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
Badlands Sas....Win win!
IMHO, The BL package is amazing in itself, and do you better in the long run.
The Sasquatch is definitely bonus.
FordVideoGuy
Tim
Salina, KS
Ford F-150
Basesquatch gets 35s include where Base Badlands would be 33s. Same suspension but Sasquatch gets you 4.7 gear ratio where the automatic Badlands will be 4.46 as standard. Manual will have 4.7.
MNBigfoot
MN
Unless things have changed the suspension on the Badlands sits a half inch lower than a Sas Bronco.
MNBigfoot
MN
The vehicle itself? That would be because of the size of the tires.
No the non-sas Badlands suspension itself. The Badlands suspension lift a Bronco .6 inches the Sas suspension lifts 1.1 inches. Also the Badlands suspension has a 1/2" more travel than the Sas suspension.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Does the base still come with a rubber steering wheel? Molle panel seat backs on Badlands were standard on my 22. Not sure about a base. Don’t forget the Badlands comes with a cooler sticker in my opinion.
Smocaine
DFW, TX
Cervelo Caledonia
It's almost the same suspension - Sasquatch gets a slightly extended bumpstop to limit the uptravel to accomodate the 35" tires - a factory Badlands will absolutely stuff that 33" into the fender.
