Aux Switches - Whatcha got wired up?
PWillette
Parrie
Maine
#1 - Winch relay trigger
#2 - Ditch lights
#3 - Bumper fog lights
#4 - Currently open
#5 - Currently open
#6 - Whinny horn
dejones64
Dan
MN
Bronco 2-dr Black Diamond
1. Rough Country Osram ditch (4)
2. DD 30" light bar
3. DD White Spots
4. DD White Fogs
5. DD Yellow Fogs
6. Amber backlighting in the DD lights 3-5
1-4 is because I hit a deer and want to avoid that as much as possible again.
Ford Bronco Aux Switches - Whatcha got wired up? lightbar
routhless
Kayla
Atlanta, GA
2017 F-150 Lariat
I'm sure I'll change this up a bit later on but currently mine is:
1. rear chase bar
2. front light bar
3. ditch lights
4, 5 and 6 currently work different functions of my fog lights (off-road, back light only, fogs only)
Ford Bronco Aux Switches - Whatcha got wired up? 404120936_10231528568381640_3513096345165889474_n
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Switch 1: KC Light bar
Switch 2: KC Pod lights
Switch 6: Rigid wheel well lights and backlight for light pods
Bruno
Bruno
Sierras
1. rear chase bar
2. front light bar
3. ditch lights
Did you wire your 3 Running lights (in the grill) directly into the existing running lights? So they are always on or at least at night?
Do you have a how-to on that (if you did)
TY!!
helifino16
Ron
Mount Sinai, NY (Long Island)
These are a very nice thing to have:
Aux1 - Air Horn
Aux2 - A-pillar Lights
Aux3 - Bumper mounted light bar
Aux4 - Smoke screen
Aux5 - Oracle Grill Letters
Aux6 - Traditional Coffee Maker
I had to switch out the Passenger Ejector seat, it didn't work most of the time.
TCoupe
Terry
South Lake Tahoe
Bronco Badlands with Sasquatch
1. reserved for future winch
2. open
3. open
4. Oracle "Bronco" lighted letters on front grille
5. White Fog lights (Mabett Raptor style)
6. Amger Fog lights (Mabett Raptor style) - great for snow as amber adds color to the snow banks
No idea what to put on 2 and 3!
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
1) Raptor 2nd set factory fogs
2) Open
3) KC Flex Era 4 A-pillar lights
4) KC Cyclone Rock Lights
5) ARB Compressor/Air Horn Relay interrupt
6) KC Flex Era 4 backlighting
Will have a separate KC single cyclone underhood - using a magnetic reed switch - just haven't gotten around to it. May use the 2nd KC from that kit as a rear cargo light under my DIY shelf.
mlugb6ro
Monte
2d Rubicon, escalade
1 open
2 front bar light in-between bumper and grill
3 under body cameras
4 left ditch light hidden in the wheel well
5 right ditch light hidden in the wheel well
6 rear lights under spare mounted on the trailer hitch
All cheap amazon stuff, mostly unnoticeable, just wanted to use the auxiliary switches, but they are useful sometimes.
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
TY!!
You can tap into the marker lights as well. Then they only come on when it is dark or the head lights are switched on.
lil_mule_4x4
lil_mule_4x4
South GA
Nissan Murano
Bruno
Bruno
Sierras
Cool, do u know the best place to do that?
And what the volts & amps are of the markers so I can check if my LEDs are compatible
NoloBronco
Nolensville Tn
I tapped into the wiring harness behind the head light. Had to remove the headlight to access. I honestly do not remember the color of wire. I believe it was green but I would confirm. I figured it out on the forum and can not find the thread now to send to you. As for the amps, I do not have a clue but would assume you are safe as I am running the raptor/marker lights in the grill, back lights for BD LP6’s and LP4’s and a light that is build into my winch all off of this tap.
Ford Bronco Aux Switches - Whatcha got wired up? IMG_7485
