Auto Start Stop Eliminator Freebie
H - 2 CHARLIE
CHARLIE
So cal.
F 150 - E 350
I thought I read just plug the trailer plug in and it won't shut off at stops , is this true ?
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
That’s what I don’t get. What’s annoying about it?
IMO it's annoying specially in summer time because when the engine shut off the compressor will do the same and the AC will start to blow ambient temperature humid air into the cabin.
On winter time, I just let it go.
P.S. I live in Houston, Tx.
blsbikes2
South Carolina
2014 Tundra
Is really smooth on the manual. As long as the pedal is pressed it will stay running. It only shuts off if you idle in neutral with clutch out and restarts before you even get back in gear.
Thanks for the info.
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
How would any of the rest of us know what you did or did not read?
Grey Mare
Tim
Man ! I cant believe the dialog this turned into. I simply asked if any one had luck with disabling the ASS using a jumper on the back side of the connector. Five pages later and no one answered :confused:
Saskwah
wess
Idaho
Land Cruiser
Yes please post all work arounds for ASS
BRBUSTER72
DAVE
NAMPA, IDAHO
'15 XTERRA '16 SUPER DUTY '18 EQUINOX DIESEL
Just being curious while at a light with the engine off, I wanted to see how hard the steering was with the engine off. Low and behold, as soon as I gave the wheel a slight tug the engine started and didn't shut off. Really though, for me the auto stop is almost unnoticeable. Rather not have it but it works well on 2 of my vehicles.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Which connector? I might be able to look it up. Haven't got my Bronco yet so can't experiment on my own, but I can read the diagrams and try to cypher what it is the jumper gizmo does
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
Not only is pressing that auto stop-start button annoying, but what about that seat belt beeping when I don't buckle up? Anyone got a bypass for that?
Grey Mare
Tim
Have a look to my first post, there’s a pic in it. I did this in my 17 F150, worked like a charm.
drew707
Ford Explorer
Actually I did provide an answer but it got buried. I’m sorry I should have tagged you. The connector that goes into the back of the control module for that section should have a brown cable in it. That’s the positive for auto start stop. However I don’t know what to do from there as I’m unsure of how this modification works.
Bmadda
Wisconsin USA
So that pic is from an f150 then? And what switch is unplugged in the pic?
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
AFAIK, the eliminators have a chip in them that simply remember the last setting of the switch. If you turned off A.S.S. previously when you start the ignition next time,the eliminator essentially activates the switch the same is if you pressed the button but without having to physically press the button. So there isn't really a wire to jump.
As others have said when you come to a stop and your vehicle shuts off, if you turn the wheel the vehicle will start back up. This is what the FORscan method does. You are telling your Bronco there is slight turning pressure on the steering wheel which keeps the vehicle running at a stop.
mbagne
Placentia, CA
Mach-E GT
I just don’t get the hate for for auto stop/start. It’s much less intrusive than just about any other auto stop/start system I’ve driven with.
Why the need to disable it?
Because it's there.
