Auto Parking brake causing issues off road
Solfive
NV
2008 JKUR
So tell me about the failure to disengage and what you did to resolve.
I was just parking in a flat parking lot near my home. No off-roading, no 4 wheel drive etc, just normal street driving. I was pulling slowly into a spot and as I started to apply pedal pressure I abruptly came to a stop. When I tried to creep the rest of the way forward the brakes were locked. I turned it on and off a few times, tried the release lever, tried applying the gas pedal to disengage, disconnected the battery…all to no avail. I was in danger of missing a job interview so I left it for a few hours and when I came back to call a tow truck I tried a couple more times to get the lever to work which again didnt work. So I tried to override it with the accelerator and finally it disengaged. I was fortunate to not be off-road like you were. So far I’ve gotten shrugs from the dealer even though I got an on screen “brake system fault” warning. I know it’s not exactly like your situation but I figure the more we document similar occurrences and keep these threads alive the more likely it may end up being helpful for others.
Big Pony
Subaru Ascent LTD '20
The steps should be:
1. Apply foot brake.
2. Shift into neutral
3. Set park brake
4. release foot brake (let the weight settle).
5. apply foot brake (won't be able to shift without doing so) and shift into park.
Using the parking brake as a habit, will prevent premature wear/tear to the parking pawl.
I was not aware of the parking brake being set automatically on steep grades.
This 👆 100%. The sequence is a transmission saver for sure. This is how I engage the parking brake on all my vehicles. It is particularly necessary on vehicles equipped with electric parking/emergency brake and those with the push pedal type. If you’ve ever experienced hearing a loud clunking noise when shifting from park to reverse or drive on an AT transmission and it made you cringe, this is probably the reason; not properly engaging the parking brake or failing to engage it at all.
NHPoke
NH
Tacoma
3. Set park brake
At BOR NH they teach switching steps 2 and 3, but either way works.
Making sure that the parking brake is set, and taking load off the parking pawl is accomplished either way.
In the category of being technically correct, you actually can shift from neutral to park without putting your foot on the brake. You shouldn't, but you can, technically.
I've also never experienced the parking brake being set automatically. I have used hill start assist, but that's different than the parking brake.
da_jokker
Jeep Wrangler JKUR
Oops....I never follow that procedure. Instead, I noticed that when applying the parking brake, you have to wait until it stops flashing...only at that point are they actually on.
So I ...
1) press brake pedal
2) shift to park
3) lift parking brake
4) wait until it stops flashing to release pedal
No settling at all.
I'll have to try the neutral method, but it's going to be hard breaking decades of habit.
Scott R Nelson
Meridian, ID
2) shift to park
No settling at all.
Your method leaves some pressure on the transmission pawl that holds it in park. The whole point of setting the brake and being in neutral (in whichever order), letting it settle, THEN going to park is that you have no pressure on the pawl.
It doesn't really matter when you're parked someplace flat - which is most of the time for most of us - but it makes a big difference when you're on a hill. So doing 2 before 3 causes more wear.
RallyGorgo
George
Spencerport, NY
2023 Ford Bronco Badlands
To reply to Tricky Mike, I have a BL manual and it does have a “hill holder” feature that engages the parking brake when you stop on an incline. I’ve noticed it on pavement but haven’t “yet” gone off-road to see how it works. To be honest, the parking brake is one thing that I’d make manual if I was changing the rear axle. The switch for the parking brake is in an awful location. And, now that I’ve had it for a couple thousand miles, the overabundance of electric/electronic “features” on this vehicle makes me nervous if they fail out in the woods.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
While traveling moderate to rough trails (steep, washed out , rocky) trails in Arizona this past week I experienced the parking brake sticking on after auto applying on a steep grade when shifted to park. The owners manual states the brake will apply when shifted to park on a steep grade, then will release manually or automatically when back in gear. The problem is it would not disengage on two occasions. Miles back in, rough country at night, not good.
Both times I was in low range in steep terrain, placed the Bronco in Park to scout the route, was unaware, but the Bronco also set the parking brake. The first time I really didn't know what was happening, by the second time I figured it out. I had to power through the brake, the obstacle and the steepness, it was about all the Bronco could do. The Bronco did not auto disengage as it should and , once I figured out what was going on, would not manually disengage. I powered through to a leveler spot, the first time it disengaged right away, the second it took about 10 minutes with on off cycles, every brake related warning light in the book, hood popping and owners manual reading then just magically released itself.
My question is, has anyone else experienced this and is there a work around? Do any of our Ford service friends @flip @Ducati1098 or @RagnarKon have an answer? Both times I was unaware the brake had set, I did not try to manually disengage until after I noticed the problem, I wonder if that would have worked?
Hi there! I can look into your Bronco's brake concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
dgorsett
dgorsett
colorado
F250, Mustang, Explorer
Idk if anyone's following any more, but I did a test today. Operating in 4L on a very steep embankment. The brake did not auto set when shifted to park and released fine manually and when driven forward or back if manually set. It seems my experience in AZ may have been a dream.
Ford Bronco Auto Parking brake causing issues off road 20240119_124716
dgorsett
dgorsett
colorado
Just bumping to see if anyone has had a similar problem yet. I have had no further issues, but still curious what happened incase it reoccurs.
Ford Bronco Auto Parking brake causing issues off road 20231204_144825-
B22-2023
Houston
Ducati1098
I’ve never had this happen, but I’m guessing it might something to do with this. Maybe since you’re on a hill (and it’s obviously aware) it requires you to manually release it instead of allowing the normal override of just pressing the accelerator pedal.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Ford recommends moving very slowly to more level ground before releasing the parking brake when on an incline.
Ford Bronco Auto Parking brake causing issues off road giphy-1401987386
dgorsett
dgorsett
colorado
Yep, that's what it felt like!
dgorsett
dgorsett
colorado
Yeah, I don't normally set the brake (yes I'm a bad person), so i don't think of it, I'll try to remember, though it hasn't happened since. This was One of the few times I had a spotter, my wife generally won't spot. If I spot myself I manually set the brake so I remember to disengage.
CalvinT
Calvin
Phoenix, AZ
Here's some info in case your brake doesn't release because of a power failure.
I keep forgetting to print this out so I can put it in my tool box.
I have no idea what would happen if you manually released the brake in the case the OP describes. It may confuse the computer.
