Auto headlight sensitivity settings
mikeeshim
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
i don't know much about electronics, but is it possible to create a switch, to bypass this sensor and on can be daylight and off can be night mode? if someone made this into the aux switches will be my hero, i hate this problem too ... help ! ! !
I can't tell if you're serious because well, it is the internet in 2022.
VIRUS
D
Wisconsin
Truck, car, feet
Take off the tint or don't use auto mode
KABQ
Aaron
Albuquerque, NM
You could just turn your headlights on and off with the switch like every single car made for 100 years.
Also, are you saying you tinted your windshield? That's very illegal in my state.
AZ_Liberty
2007 Expedition
Even without a tint on the windshield, the sensor is stupidly sensitive. My dash is strobing during my drive to work every time the shadow of a tree hits the sensor.
It's just really bad with low sun angles.
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
That’s what it boils down to.
mikeeshim
mikeeshim
Los Angeles, CA
I can also go back to morse code, but mobile phones are so much more convenient, like auto headlamps. Also, I see so many people that are driving at night with their lights off these days. I'd rather have auto then not.
As for the legality of the tint, I live in southern CA, where you can get away with anything these days. Also, it's a 100% clear tint, so just for heat and UV deflection without any color.
Cbiggs
Cory
Well, guess I'm going back to the drawing board.
It’s annoying though, you’re not alone. Minor one to me. Probably most annoying to the lower vehicles in front of us.
Ryslegit
SoCal
22 Bronco Badlands Sas
I have the same issue with clear ceramic tint on the windshield. After searching for a solution and having the dealer check it out, I’ve learned to deal with it.
Ctholl
Casey
WY
Jk wrangler (bronco on order)
Strange, I literally tinted my windshield 30% tint and I have no problems. Now I'll be mounting a dash cam in front of the sensor as well and curious how that will affect it
Ford Bronco Auto headlight sensitivity settings PXL_20221012_205654239
mikeeshim
mikeeshim
Los Angeles, CA
Did you use a ceramic tint as well?
mikeeshim
mikeeshim
Los Angeles, CA
Unfortunately probably not. Where I went supposedly had a good reputation and it was inexpensive but I left with more to be desired for quality.
I'm starting to see a pattern. The ones that have ceramic tint on the windshield are having this issue only, which means the ceramic is blocking more of whatever the sensor is reading.
