Auto headlight sensitivity settings
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Question: Is there a way to change the sensitivity of the auto headlights? I tried doing a search and could not locate any info.
Recently got ceramic tint all around, and the headlights are now constantly turning on and off during the day, which wouldn't be a big problem if it were just the headlights, but the brightness level of everything else, including the indicator lights on every panel keep going dim and bright on and on.
Also, changed the Forscan settings so my DRL bar is orange, but only stays orange when the lights are off, so they turning orange and white, which could be misleading to some cars in front of me.
TIA!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
You can't change the sensitivity.
TTT
Alberto
Baja
Mustang Mach E Premium
try placing a small light in the sensor? sounds stupid but is there's any other options ?
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Following as I cannot stand how it dims during darker conditions. Let me control that ford!!!
FleshTuxedo
A
PA
'22 OBX 2dr.
Use the little button(s) to the left of the steering wheel. You can brighten it up.
zyglyrox
Cory
Cleveland
I understand that. But due to changing conditions in light it’ll go from “daytime brightness” which is max, to my setting which is fully down but still with the daytime white dashboard. And it’ll flicker between the two.
Crash98
Viet
Bremerton, WA
2017 Ford F-150
I just change the settings on my sync screen to night mode only and I usually keep my dash lights at the minimum, so I don't notice when it switches back and forth. In fact the only way I know my lights came on is when the indicator shows up on the dash.
My bars are also set to orange for DRL. I really don't think the lights are switching on and off that much to cause confusion. If they were, then your headlights coming on and off rapidly would be the cause for confusion.
mikeeshim
mikeeshim
Los Angeles, CA
Sounds like you need the ceramic coating off the sensor.
The ceramic tint is on the inside of the glass, like a normal tint. The sensor is about 2 inches from the windshield on the dash. If the sensor was attached to the windshield, I would have cut around it being where it is, I'd have to cut a pretty large hole to account for the direction of the sun.
mikeeshim
mikeeshim
Los Angeles, CA
I notice it the most on my hero buttons because they light up pretty bright orange and go very dim. I'll try changing everything to as dim as I can, see if that helps.
And I wish my orange DRLs would stay orange because I prefer that to white.
mikeeshim
mikeeshim
Los Angeles, CA
Might be a bad idea during the darker times of the day.
TTT
Alberto
Baja
i don't know much about electronics, but is it possible to create a switch, to bypass this sensor and on can be daylight and off can be night mode? if someone made this into the aux switches will be my hero, i hate this problem too ... help ! ! !
Crash98
Viet
Bremerton, WA
2017 Ford F-150
Yeah I think everyone wishes they would stay orange
22OBX
Hartford, AL
You can. You can auto control your headlight by overriding auto
zyglyrox
Cory
Cleveland
Thing is, is the headlights aren’t coming on, I’ve had it happen due to the shade of the sun causing a shadow on the light sensor. I know I can turn my lights on.
