- Joined
- Jun 15, 2020
- Threads
- 1
- Messages
- 541
- Reaction score
- 972
- Location
- South Texas
- Vehicle(s)
- F150 SuperCrew 22 Badlands
- Your Bronco Model
- Wildtrak
Looks kinda close to the 2D’s room now. He’ll be fine.No cargo room now
Used line-level inputs, not a converter.Question for the OP, did your amp use line-level inputs or did you use a Line to low level converter?
I can't see how an amp could feedback through a line converter, but genuinely curious.
How do you go about looking that information up? Are you a service tech?This is why I'm wanting the VIN. If they opened a Hotline case or started warranty cancellation on a component it's one thing but I highly doubt they messed with it. My question to the OP is if they told him the specific thing that caused the failure. If he removes the amp and other add-on audio equip, pays for a new ACM/APIM and it doesn't fix the concern then who's on the hook? Was it misdiagnosed? Likely not but if they don't tell him what killed it, how can you be sure it's not going to happen again?
I'm a dealer and have seen the dealer hopping a bunch, rarely is there anything in OASIS because a diag claim was never run, dealer never went through with cancellation and Hotline notes don't show up unless you have a contact ID or dig through complete warranty history. Most of the time there are only scant tech notes to go off of. Hell, Ford has sent known owner caused problems to us to fix under warranty. Yea, not a fun conversation to have after "Ford" told them it was covered.
My point is getting the correct diag so the cause can be corrected before a new part is bolted on, programmed only to find out it still hummms.
I didn't know the Bronco has low level outputs. So you connected RCA cables directly from the vehicle to the inputs on the amp? What amp?Used line-level inputs, not a converter.
Amp is JL-Audio VX700/5i.I didn't know the Bronco has low level outputs. So you connected RCA cables directly from the vehicle to the inputs on the amp? What amp?
Some amps accept high level inputs, the OP's amp is apparently one of those. You connect speaker wire input and then run speaker wire outputs.I didn't know the Bronco has low level outputs. So you connected RCA cables directly from the vehicle to the inputs on the amp? What amp?
Oh, ok. I get it now. Apparently some vehicle head units have issues if they are powered up and speaker wires aren't connected to actual speakers. Must sense there is little/no resistance going to your LOC. There's a device to compensate for that. Call Crutchfield.Amp is JL-Audio VX700/5i.
There are no low level outputs in the Bronco so I connected the audio output from the Bronco to the amp using speaker wire to RCA adapter.
I am a dealer that oversees fixed operations which includes parts, service, body shop, wholesale, heavy truck and trailer departments. My brother handles the sales departments.How do you go about looking that information up? Are you a service tech?
Well, I guess if you're gonna have tires that are oversized...No cargo room now
It hits pretty good for a single 12. They were originally going to set it up to down fire but changed plans.Well, I guess if you're gonna have tires that are oversized...![]()
Just an fyi. There is no amount of music listening that could ever justify 11k on a speaker system. Especially in a vehicle with such a poor sound stage. My mind is just blown. So for that money you now have a. No cargo or extra storage space. B. No one outside that speaker shop that can work on this system if there is a problem. C. No chance ever to recoup the cost d. You will be deaf or have substantial hearing loss and realize at that point what a dumbass younger you was.No cargo room now
Lighten up FrancisJust an fyi. There is no amount of music listening that could ever justify 11k on a speaker system. Especially in a vehicle with such a poor sound stage. My mind is just blown. So for that money you now have a. No cargo or extra storage space. B. No one outside that speaker shop that can work on this system if there is a problem. C. No chance ever to recoup the cost d. You will be deaf or have substantial hearing loss and realize at that point what a dumbass younger you was.
What I can’t hear you……Lighten up Francis
JBL DSP4086Hopefully the amp you bought has input protection; not all do. Even if provided, the design of input protection can affect the systems performance.
https://www.analog.com/en/analog-dialogue/articles/amplifier-input-protection-friend-or-foe.html
