Voided Warranty question
luvmybronco
Loudon, TN
1968 Bronco sport, 1969 Bronco sport, 1990 F250 Lariat 4x4, 2015 F150 Lariat super crew 4x4
This is probably a stupid question but was wondering if the JKS max tire kit and Eibach spring replacement on non Sasquatch badlands would void the factory warranty?
I have a 2 door non Sas Badlands that I want to get a little more lift to clear true 35” tires. Eibach says 1.8” in the front and 1” in the rear for their Spring replacement on non Sas Bilstiens. I figure after my bumpers, winch and gear, it’ll probably settle back down to maybe 1/2” higher than a Sasquatched Bronco.
Does anyone have info on if either JKS max tire kit (cutting off crash bars) or replacing the Badland Bilstien springs to Eibach void’s warranty?
Maybe @fordmotorcompany can answer this?
Felix808
SRV CA
It's dealer by dealer & Ford's case by case. Would have to be relevant to the problem. It shouldn't void the warranty on the infotainment system for example 🤠
Jdyount
Kansas
2021 Badlands
It's not going to completely void your warranty, BUT it does mean there are going to be some things they will not cover under warranty (like a broken CV shaft in my case). I have the Eibach Coil-overs and 37's and they did NOT cover my CV. The warrant reads something like: "Damage caused by aftermarket components is not covered".
omi205
BoJack
Austin
And this is why I am sticking to stock Badlands Sasquatch as much as possible. Have the esp to 7years/100k miles and want to make sure im covered all the way through. But I almost pulled the trigger on the eibachs too. Then stopped because of this worry.
