Voiding warranty on rear camera question.
Dylan pasty
Dylan
Portland Oregon
Bronco 2 door
Howdy,
Looking at buying a tailgate reinforcement/mounting system. If I was to install this would they void my recall for my rear camera? (Assuming installing would cause for me to alter/move or mount to the camera and tire holding area?
Ducati1098
As long as the camera isn’t modified, won’t have any bearing on the warranty of it. Putting a reinforcement on isn’t going to harm the camera in any way.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Unless you accidentally smashed the camera with the tailgate enforcement when installing it, most dealers probably wont deny you warranty coverage.
However, don’t fall into the Magnuson Moss trap that many people do and think that just because it’s illegal, they won’t deny you coverage.
Here is a good read on the subject:
https://www.tacomaworld.com/threads/ffs-lets-all-stop-referencing-the-magnussen-moss-act.609911/
My attitude is that i if you’re that concerned about warranty, maybe leave it stock until warranty is up.
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
The only leverage you have as a customer is making a big enough stink to convince other people not to decide to buy the vehicle…and nobody is going to be swayed.
The Turn Offroad required me to splice an extension into my camera harness - so that probably voided the camera warranty right there. But that tends to happen when you cut and splice into things.
there is a different analog camera that didn’t need a splice and could use an extension. I didn’t hav that camera of course. I don’t know if it’s a different camera (360 vs non-360) or a Model Year revision or what
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Others are correct, it will not void your recall.
I will say this: IF they have to remove the aftermarket component to replace/repair the rear camera, they can charge for the removal of that aftermarket component. In my experience they usually won't unless it's going to add a bunch of added labor, but they can.
Still won't void any warranty/recall.
Edit: Corrected
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
This is the critical part most people are overlooking. The answer to your question is yes. I am a consumer warranty defense attorney.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Actually Ford will pay the dealer reasonable clock time to remove and install any customer added accessories in order to perform a warranty repair or a recall. Problem is, many dealers don’t know that.
RagnarKon
Bryan
New England
MmmMMmMm. I stand corrected. I wonder what kind of limits there are for "reasonable clock time".
Brother-in-law had a winch on his truck. In order to do a warranty repair they had to remove his winch and bumper, which to be fair, added a good 1 - 1.5 hours or so to the job, and they charged him. I asked my dealer, who frankly has never charged me to remove anything aftermarket I've added. They said they could charge, but they typically don't unless it's an excessive modification (whatever that means).
So now I'm wondering if my dealer just bills the difference of whatever time Ford is willing to give them.
BadlandsA51
Craig
Kansas
If a dealer charged 1.5 hours to R&R a winch and bumper for access to a warranty repair, that wouldn’t be a problem. I say that as a retired Field Service Engineer with Ford, I dealt with many similar situations. If they claim 4 hours, that would raise some eyebrows.
I’ve seen the dealer claim it under warranty AND bill the customer and tell the customer that Ford won’t pay to do it.
RagnarKon
Bryan
New England
Gotcha. Good to know—I'll have to text my brother-in-law for the future.
Wish I had more info so I could pass it by you, but I can't say with any real confidence exactly how it went down. I imagine there can be a bit of a gray area with this sorta stuff, but good info regardless.
MC1313
DolphinsMark1313
2023 Bronco
We have to do this all the time with medium duty truck repairs because of all the different upfitter applications.
on a side note is there any insight you can provide on why the 2.3 on cold start up (outside ambient temps cooler 50degs and lower) that it will octane ping until temps inside the engine bay warm up?
ford says it’s normal but this never happens when hot outside or when the sun is beating down on the hood warming up the engine Bay Area. I have 35 years in the business working for several manufacturers and have written hundreds of field product reports and would have to think it has to be one of the sensors.
and I know for sure it’s an octane ping and not turbo or injector noise.
Wastegate rattle is very common (and normal) on these under those exact conditions and could very well be what you are hearing.
MC1313
DolphinsMark1313
2023 Bronco
Yes but it’s not a waste gate noise. I have looked into that and it’s clearly an octane ping.
I isolated the waste gate and still the noise is present.
