Are Your Automatic Updates On?
Is Your Bronco set to "Auto Update"?
  • Total voters
    112
  • Poll closed .
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Exactly why I asked how to turn auto updates off. How? First time flat towing this weekend.
@Fordified1
Accessory mode, center touch screen, Settings, swipe sideways to find & tap Software Updates, top line Automatic Update = toggle off, select Continue at nanny prompt.
Also at that same screen, for Recurring Update Schedule, I created a custom schedule for just 2 days a week at 2:00 AM (when I’m sure I won’t be flat towing) just in case I forget and leave Updates turned on.
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
Apparently the best guidance is automatic updates on, but no schedule set. That way you can manually review any that are downloaded before they install.
I'm in the camp of wanting the most recent version of all software installed personally, because of added functionality and the fixing of bugs.
DBX2
Tennessee
2025 Stroppe; 2025 Harley RG3; 2025 HD Street Glide; 1997 HD Heritage Sp
I turn whatever I can, OFF. When FORD owns/buys my vehicle, they can update all they want. So tired of my data being the subject of everyone and anyone. I still get email updates on vehicles I haven't owned in 5-10 years. Enough.
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
Just went to dealer yesterday. They installed 4 updates one of them to do with flat towing. Don't know what other ones were for. I have OTA updates turned on and had one on April 4 that showed on Fordpass. They obviously aren't doing all updates OTA. Check Fordpass on available updates. One I needed was listed in the 4x update.
userdude
Denton, TX
2023 2dr Badsquatch
I get regular email updates about a '22 OBX I never owned/looked at/etc. Hey, whoever you are, Ford would really like you to bring it in for an oil change, it's time! lol :whistle:
Meanwhile, never gotten a single one for the actual '23 BL I do own... 🤦‍♂️
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
My updates never worked, likely never will work, and have to be manually done with FDRS apparently.
Why don't your OTA's work?
mpeugeot
I suspect it's because my Bronco isn't fully spec'd/programmed as a "USDM" market car. It's a fleet unit sold thru some European holding company as part of the military auto sales program. I don't have proof, but there are some oddities with it.
Correction, I did get one update, one time in late 2021. Otherwise, even spinning a dead chicken overhead and chanting while talking to Ford support wouldn't fix the problem.
rugedraw
Javier
Miami, FL
Do any of your connected services work?
If you have FORScan or know how to pull the as-built data on your truck, go to this line in the TCU. If in the 754-10-01 location you see anything other than 5553 14, then your TCU is registered to another country and that's your problem.
Or send me your VIN and I'll poke around to see if I see anything.
Ford Bronco Are Your Automatic Updates On? 1713472370015-ms
mpeugeot
Yes, all my connected services work.
My TCU is registered as 5553-14.
I will send you the VIN.
Mr Bacon Jr
Gary
Santa Fe, NM
Yeti SB130
Although mine is set to auto update, I also haven't received an OTA update since September 2023... So I'm assuming that's a good thing 😁
Or wifi and auto update have been mysteriously turned off. Which was my case- found several other radio switches turned off that I know I had on. Ford is definitely not a software company.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
In my case, everything else was still active and connecting fine.
ChrisB351
Shreveport, LA
If youre financed thru ford motor credit then they technically do own it 🤣
CrypticOne
Denver
Would you be willing to look into my VIN as well? I have been stuck forever.
Thanks!
