Alternator Upgrade
da_jokker
Jeep Wrangler JKUR
If that doesn't solve it..wonder if that battery monitoring sensor that attaches the negative post is having issues? After all that is the censor that the Bronco uses to monitor everything.
I hooked my winch negative to that open hole, and I've been wondering if I should be running it directly to the battery or not. The idea of pulling that many amps through that sensor does worry me a bit.
zuke
zuke
Stafford VA
I hope my winch negative to that open hole, and I've been wondering if I should be running it directly to the battery or not. The idea of pulling that many amps through that sensor does worry me a bit.
That's a pretty fair question!
My winch negative is hooked (Well Not hooked at all at the moment..) to the opposite side of the sensor from the battery, and I have, I think, 3 pulls on it while hooked up that way. Last pull was in September. And it hasn't seemed to have caused problems with the sensor, but then we all have seen failures that aren't immediate..
Wasn't motivated enough last night to deal with the cold, so Didn't do anything with it, Just about to head to the shop now and start doing more testing...
da_jokker
Jeep Wrangler JKUR
Well that's good to know. It feels strange running all those amps through that sensor, but maybe with designed to handle it (Wonder what the amp rating is And actually, to amps even come into play when we're talking the negative side?)
Of course, you are having electrical problems :ROFLMAO:
tdiddy
Tommy
Illinois
2010 Ford F150, 2012 Ford Focus
The Ford Performance Winch instructions (step 44 on page 28) says to connect to the negative post open hole so I would think that's the correct location.
Ford Bronco Alternator Upgrade Screenshot_20221224_090353_Driv
zuke
zuke
Stafford VA
Boy that's the truth! :ROFLMAO:
I'm guessing, But not willing to cut the sensor apart to find out... That the sensor is not reading amperage or voltage directly.. Probably an inductive or shunt setup in there..
zuke
zuke
Stafford VA
Well, I wish I could say something conclusive from my measurements so far.
I chose 4 points for measurement as shown in this picture;
Ford Bronco Alternator Upgrade 1671908956451
Measurement from "G" to motor was 0 ohms at all times
Cold, before removing fog ground, sitting in the shop;
A 0 ohms
B .1 ohms
C 275K ohms
D .2 Ohms
Warmed up, Ran for a while, Nothing else changed.
A 0 ohms
B 0 ohms
C 250K ohms
D 0 Ohms
Fog Ground removed, still warm;
A 0 ohms
B 0 ohms
C 82K ohms
D 0 Ohms
Cooled back down, Ground removed;
A 0 ohms
B 0 ohms
C 2k ohms
D 0 Ohms
So it looks like removing the ground (Which allows the ground plate to lay flat on the body surface) seems to make a ppretty big difference at the one bolt, but not really much difference at "D" which is the cast aluminum bracket across the top of the radiator.
Current running through the body ground was not a really useful measurement, as it varied from .6 to 8 amps in every configuration I tried, Voltage difference in the different points (with engne running and not running) were pretty variable, and didn't look to be useful measurements either..
The resistance was obviously different with the ground removed vs in place, but I don't know if these numbers are big enough to really represent a problem.
da_jokker
Jeep Wrangler JKUR
A 0 ohms
B .1 ohms
C 275K ohms
D .2 Ohms
A 0 ohms
B 0 ohms
C 250K ohms
D 0 Ohms
A 0 ohms
B 0 ohms
C 82K ohms
D 0 Ohms
A 0 ohms
B 0 ohms
C 2k ohms
D 0 Ohms
C does seem to fluctuate quite a bit. Did you check the grounds up by the firewall? I know there's a couple of smaller wires along the cowl edge. Actually there's probably ground wires all over the place So it may be a losing battle.
And I'm assuming you've already done the basics of making sure all the fuses are seated and the fuse box bolts and nuts are all tight? (Just because that's a known source for electrical Gremlins)
da_jokker
Jeep Wrangler JKUR
Nice find! That's perfect, I feel better moving it there now.
Side note.. 1/0 wire is tough to work with and manipulate. May have gone with just 1 gauge if I did it over.
zuke
zuke
Stafford VA
I'm thinking C is just not a very good choice to check, it's holding the structure to the frame, but the structure itself showed a good 0 ohms all the way across, what I should probably do is run some checks to points on the cowl and modesty panel back to the battery negative. I'll probably do that today, alhough everything acted normal on the way home last night.
I went over the fuse panel way back when I first put in the amps, because it had already been noted as a problem area then, but I went over it again yesterday as part of my checks. Didn't find anything loose, but tightened everything another quarter turn, and checked the seating of fuses. I hooked the amps and fogs backup, I redid all the wiring on the fogs, and checked for resistance and voltage drops. There was a voltage drop across the first pigtail I did, and a pin in it that wasn't latching right..
It could be a combination of multiple things, and I may have solved it already, but only time is gonna tell.
I worry about the longevity of modern car electrical systems, while reading about the many similar electrical problems others have had, several times the solution was replacement of a sub wiring harness. In ten years it will be very hard to find harnesses and the individual custom electrical connectors that are prevalent in modern cars... Hell, I can't find pins for C1400 now!
zuke
zuke
Stafford VA
Thinking further about it today... If I'm getting 0 ohms across the upper radiator mount, and a lot of resistance on that bolt marked as "C", Where is that ground path on the brace coming from? I think that's worthy of investigation today.
It could simply indicate that just that one bolt is isolated by paint in it's threads or something similar, or it could indicate the the entire structure the bolt goes into underneath doesn't have a good connection to ground. I'll check the bolt on the opposite side first, and then see if I can find a good point to check the area underneath the brace.
I see at least 6 bolts in the thing that it could be grounding through;
Ford Bronco Alternator Upgrade 1671985508334
