Aftermarket frame mounted hitches?
sportcoupe
Georgia
2023 Bronco
I see nearly all hitches. including OEM, are not directly mounted to the frame rails. They are mounted to a smaller crossmember. Are there any aftermarket hitches that do attach to the primary frame rails?
sportcoupe
sportcoupe
Georgia
2023 Bronco
I'm not planning on exceeding 3500 lbs at all. I do want a more robust hitch receiver than my OEM hitch though, preferably frame mounted..
userdude
Denton, TX
2023 2dr Badsquatch
Y'know, I want a rear winch. I know they use a brace, but I wonder if those are frame mounted? 🤔
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
while not exactly what you want, i believe the raptor version of the hitch adds some extensions for rigidity, between that and a rear sway bar or something it raises the towing rating a bit. i haven't see anything that raises you a whole class tho if thats what you're after. i would think there is stuff in the way of directly mounting.
FloridaBurgBronco
Don
Middleburg, FL
'24 4Runner TRD, former '22 Bronco Badlands owner
I got a Curt aftermarket hitch, it suits me fine, I may occasionally tow a small trailer but mainly use it for bikes and very small stuff like that. I mean the tow capacity is small anyways. It's mounting position is pretty robust. I did use it for a recovery a couple times and it's not bent or anything at all. Having said all that, it's not as solid as a full size receiver hitch for sure.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
Second this, plus it’s simple to install.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Ford's lawyers wouldn't let them sell a vehicle with a subpar hitch mounting setup.. I feel like your worry is unwarranted.
Realistically.. the factory mounting setup is probably capable of handling at least a thousand pounds more than advertised... for liability reasons. Much like ladders are required to support 3 or 4x the weight they're rated at.
sportcoupe
sportcoupe
Georgia
2023 Bronco
BlueWaffle
Maine, USA
How can that one be rated for 675 lbs tongue weight when the OEM receiver is only 350 lbs tongue weight?
Considering its extended nearly a foot I'm betting its a typo.. should probably read "67.5 lbs tounge weight" 😋
sportcoupe
sportcoupe
Georgia
2023 Bronco
I can't find any aftermarket hitches that do attach to the primary frame rails so....
Are there any aftermarket rear bumpers that have an integrated 2" receiver?
Gtrekker
Gary
