Aeroskin II Hood Protector Question
bacon1987
2026 Bronco Outer Banks
I was looking to buy the Bronco 2021-2026 Aeroskin® Hood Protector by Husky Liners® - Smoke from Ford but I'm unsure about the color. I have a Black OBX and I wanted it match the grey textured plastic that I have for the fender flares. Should I get the "Smoke" colored one in the link above or the black one? I can't seem to find pictures anywhere online of he smoke vs the black for this hood deflector.
The SKU for the smoke is: VM2DZ16C900AB
Any help would be appreciated
23OBX2.7
AB Canada
2023 Bronco
prety sure those ar smooth while the other one with aero bump and optional fender and quarter panel caps are textured and look great IMO.
Dan-O
Dan
Fountain Hills, AZ
As “23OBX2.7” stated, the smoked is smooth finish, and over time it will show rock dings, scratches etc….. I think the black textured looks better, and it will most closely match your textured flares. Many members here on the forum have the black textured Aeroskin II which has the hump on rear edge. I had one on my ‘21 but took it off because it made some wind noise at freeway speeds that I just couldn’t get over.
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
I had one on my 2023 Oxford White Bronco. Protected the leading edge of the hood like it was supposed to do. Not sure how many stones it actually stopped from hitting the windshield. What I DIDN'T like was the way dirt collected underneath. Water naturally rolls off the hood and eventually gets "behind" the Aeroskin and brings debris with it. Then, when I removed it, there was noticeable paint discoloration. A LOT of elbow grease and cleaner wax and I got it back to where you couldn't see it anymore. I won't put another one on. Maybe protective film instead.
Ford Bronco Aeroskin II Hood Protector Question 2023 Bronco Hood Protector
Kenmra150
2023 Ford Bronco Big Bend
I bought a used 2023 Big Bend that has the front, as well as the front and rear corners. Luckily the previous owner put PFF down on all those areas before he applied the armor. FWIW, the factory look and full protection is a nice detail for me as most miles will be on highway.
23OBX2.7
AB Canada
2023 Bronco
IMO the commercial thickckness PPF is the way to co because standard PPF will get shredded quickly / 3 yeears on hoof and fender leading edges as it did on my Mustang with limited high density highway use anytime.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
Not sure why this item isn't standard package equipment. It does make a HUGE difference on bug soup on the windshield. Only the largest rocks and insects seem to get through.
Mean Green
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
My only bitch on the black is color fade. Otherwise, it works great for me.
Ford Bronco Aeroskin II Hood Protector Question IMG_3997
Ford Bronco Aeroskin II Hood Protector Question IMG_3996
Ford Bronco Aeroskin II Hood Protector Question IMG_3998
