Advice on fitting 50" tires.
Rick Astley
Up Doug's ass
d
Stumbled across this off road rig on 50" tires and think I want to try and fit a similar set on the Bronco.
What will I need to modify? UCA's and crash bar relocation? What else?
Ford Bronco Advice on fitting 50" tires. 20230715_104229
Tires are 1000/50R25's
Ford Bronco Advice on fitting 50" tires. 20230715_104305
BigFootie
Wisconsin
I hear those are boulder throwers, you may want some industrial mud flaps!
HoosierDaddy
__ Eric
NW. Indiana
What else?
Spare tire relocation bracket and third brake light extension.
You might need some spacers/lug pattern adapters depending on what lug pattern those 25's come with.
You might need to regear the diffs, unless you have an automatic, those multiply the torque and that fixes almost everything.
I'm not certain you'll be able to recalibrate the speedo, even with Forskin.
spuddy59
Chase
Lubbock, TX
2023 Bronco
What’s the offset on those wheels? It’s hard to give you any help without some information first.
MNBigfoot
MN
I just removed the crash bars, no rub with mine, and 3.73 gears are fine, don't let anyone tell you otherwise. I'll post photos once my billet classic bronco emblems and fiberglass mod hard-top arrives.
