This is a non-comprehensive list of stuff you can do without needing a programmer/scan tool. Shamelessly copied and pasted from other sources, just putting it in one location. If there are more, or updates/corrections, I'm happy to update the original post with them. I made this so I can print it out and stick it in my glovebox because I can never remember it.
How to turn on Brake Maintenance Mode:
1) Turn ignition ON
2) Turn parking brake OFF
3) Press and hold down accelerator, and at the same time press and hold DOWN/OFF parking brake. Keep holding until you get to step 5...
4) Turn ignition OFF, pause for a second, and then back ON
5) Turn ignition OFF and release parking brake and accelerator, the screen should now indicate Maintenance Mode
**DO NOT try to drive with this mode on, your brakes won't work well!
How to re-engage normal brake service:
1) Turn ignition ON
2) Press and hold down accelerator, and at the same time pull and hold UP/ON parking brake. Keep holding until you get to step 5...
3) Press and hold down brake pedal for 2 seconds and then release
5) Release parking brake and accelerator, the brake warning lights and check engine lights should go off, you may need to start the engine to clear everything out
Brake Maintenance Mode for 2.3L where this procedure does not work
FDRS is the "official way".
The latest version of Forscan has service mode procedures that allows this as well
- NOTE - when exiting BMM, do NOT press the brake when Forscan tells you to, just click OK, otherwise it will fail and tell you to try the code above.
RESETTING THE BATTERY SENSOR
When you install a new battery, reset the battery sensor by doing the following:
1) Switch the ignition on, and leave the engine off.
Note: Complete Steps 2 and 3 within 10 seconds.
2) Flash the high beam headlamps five times, ending with the high beams off.
3) Press and release the brake pedal three times.
4) The battery warning lamp flashes three times to confirm that the reset is successful.
ProCal Rev Matching: How to Activate
(NOTE - FORD removed this from ProCal as of 2024 - if you have this and want to keep it, do NOT update your ProCal tune. If you do not have it and want it - I'm sorry)
1) Key must be in the on position (It does not matter if the engine is running).
2) Vehicle must be at a full stop
3) Hold the brake pedal down
4) Hold the speed control “+” button down until the tachometer reads 8K to indicate the input has been received (about 3 seconds).
5) Release the speed control “+” button. The tachometer will read 4k for 2 seconds to indicate the feature has been turned on.
6) You may release the brake pedal when safe.
7) The feature is active and the vehicle ready to use.
ProCal Rev Matching: How to Deactivate
4) Hold the speed control “-” button down until the tachometer reads 8K to indicate the input has been received (about 3 seconds).
5) Release the speed control “-” button. The tachometer will read 2k for 2 seconds to indicate the feature has been turned off.
7) The feature is deactivated and the vehicle ready to use.
Window Reset Procedure
Carry out all steps within 30 seconds of starting the sequence.
1) Close the window.
2) Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for two seconds.
3) Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for two seconds.
4) Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a two seconds.
5) Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a two seconds.
Disable Seat Belt Chime
1) Sit in the seat you want to disable the chime for. (you will have to do it individually for all seatbelts you want to disable)
2) Push the ignition button with the key in the truck and without pressing the brake pedal. (So the ignition is on without the truck running)
3) Wait for the seatbelt light to go out.
4) As soon as the seatbelt light goes out buckle and unbuckle the seatbelt 3 or 4 times until the seatbelt light comes back on.
5) Buckle and unbuckle the seatbelt one last time, the seatbelt light will flash a few times letting you know you did it right.
Clear Flood / Flat Crank Mode:
Hold down the gas and brake (or gas and clutch for 7MT) at the same time and press the start button.
Flood mode stays engaged while pressed, or for a default 5 second
Sync Reboot:
Hold Audio Power + Fast Forward until screen goes black (about 10 seconds)
Bezel diagnosis and speaker walk around test:
Ignition on, audio in AM/FM mode
Simultaneously press and hold the on/off button and the seek down button
Dealer Test Mode (Engineering Test Mode):
To enter the IPC engineering test mode or dealer test mode, begin with the ignition off. Press and hold the RH steering wheel switch OK button. Ignition on and continue to hold the button for 5-8 seconds until the display indicates Engineering Test (ET). Press the up or down arrow buttons to navigate through each of the display windows. To exit the IPC dealer test mode, press and hold the OK button for 5-8 seconds or place the ignition in off. Each down arrow button press advances the viewing window to the next set of items.
TPMS Reset (with tool)
1) With vehicle off pump the brake once, key on, key off, key on, key off, key on but leave on. (5 presses)
2) Pump brake once more.
3) Now cycle the key 3 more times. On the 3rd time it should beep telling you tpms reset has been activated.
4) Using a TPMS relearn tool (Motorcraft TPMS19) - click the tires in order by the valve stem: DF, PF, PR, DR
TPMS Reset (Air Pressure)
1) Place the ignition in the off position and keep the key in the ignition.
2) Without starting the engine, turn your key to the ON position.
3) Quickly switch the hazard flashers on then off 3x.
Once your vehicle enters TPMS reset mode, the horn will sound once and a message will appear in the information display. If this does not occur, repeat the sequence.
4) Decrease the air pressure in the driver-side front tire until the horn sounds once.
5) Decrease the air pressure in the passenger-side front tire until the horn sounds once.
6) Decrease the air pressure in the passenger-side rear tire until the horn sounds once.
7) Decrease the air pressure in the driver-side rear tire until the horn sounds once.
8) Turn the ignition off.
General Reset for Wierdness
Unplug the negative battery terminal for about 5 minutes
Reconnect the negative terminal
This reboots all the modules and computers in the Bronco​
Use a trickle charger rated for AGM batteries:
Connect (+) to the (+) battery terminal​
Connect (-) to either chassis ground or the side tab on the (-) battery terminal​
DO NOT connect directly to the (-) battery post​
The BMS system must see the charger and going directly to the (-) battery post will bypass it.​
Let the battery trickle charge over night. Low battery voltage, or just the BMS thinking there is low battery voltage, can cause a lot of odd things to occur and this corrects for that possibility.
Does the Pro Cal rev matching work for all MTs or do you need a tuner of some kind.
Need to have the Ford Performance Calibration installed I believe. I haven't heard if there is a way to enable it without that.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Whoa! Can’t wait to give that seat belt chime trick a try
thanks for sharing
timhood
Tim
Several
Is this supposed to be used before changing pads and/or rotors? I'm not familiar with this from my experience with other Ford vehicles.
thesocalexplorer
Joe
Southern California
Great list, thanks for adding. If only rev matching could be unlocked out the box without the need for the performance tune. Onwards with heel-toe downshifts...
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Hokey Pokey mode
  1. You put your right foot in
  2. You put your right foot out
  3. You put your right foot in
  4. And you shake it all about
  5. You do the Hokey Pokey and you turn yourself around
That`s what it`s all about!
Supposedly - yes. It will pull the e-brake pin out from the caliper and allow you to remove the pads from the caliper.
I've pulled the caliper off the rotor without it, and had the rotors all the way off, but I've never tried replacing the pads, so I don't know what it would do if you tried to do that without entering Service Mode.
That said, I can't get Service Mode to work on my Bronco, and there are at least a couple of other folks posting here with the same issue. Apparently you can do it with FDRS as well (but that requires either a trip to the dealership or a paid license and compatible dongle).
Tacoman
Matthew
Fayetteville, AR
2026 Shelter Green Braptor, 2026 Defender 110, 2025 Badlands
How about how to turn the idiotic chime that chimes multiple times when you set cruise!
