4x4 system how does it wo
markregel
Lincoln, NE
Pont Vibe
  • Thread starter
  • Banned
  • #1
With the standard 4x4 on base and big ben, if a wheel slips does the system route torque to the wheel(s) that are not slipping? If so, how does it do this?
markregel
markregel
Lincoln, NE
Pont Vibe
  • Thread starter
  • Banned
  • #4
Open diffs.
It will independently brake the wheel that’s spinning to force the wheel with traction to move.
Thanks! What l was looking for. I'm not an off roader and deciding on locking rear or not.
EvlNvrDys
Hunterdon County, NJ
My guess is you will probably never need it then. But usually people go for the gears that come with the locker, 4.27's or 4.46's. But plenty of people will get by with the open rears.
Ambassador
Standing_Bear
Honda Civic, 2022 F150 Raptor
It comes with fancy knob. Just turn and have fun. One more turn and Bronco tells its wheels why you turned it for!!!
Makes a amateur to be a pro
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
The only reason why you should get a locking diff when you know you'll never use it is for resale in ten years.
And that won't account for much.
ssolypop
Solomon
Hawaii
Avenger
If you can afford it, then go with the the upgrade it won't hurt you any and it leaves room for you to explore a new hobby. But dont let all the bells an whistles pull you from your budget... that's my opinion ?
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
Jeeps and a Subaru
The base manual 4x4 system goes from 2wd where the front drive shaft is free spinning to locking the front and rear driveshaft so they both rotate at the same speed all the time. This is not recommended on dry pavement as the driveshafts need to spin at different speeds when you turn around corners. It's fine off road where wheels slip anyway. With this system, if you lose traction on one tire, the tire on the other side won't get any power until the computer traction control kicks in.
The automatic 4x4 upgrade package has a differential in the transfer case so that the driveshafts are connected but allowed to rotate at different speeds. This can be used on road without worry. Some of the GOAT modes may lock the driveshafts together for off road modes. Someone else who knows for sure can chime in to verify that. With the differential in the transfer case, losing traction at one tire will cause all of the energy to be diverted to that one tire. Of course, the computer traction control will sense this and apply the brake to that wheel and some of the energy will be diverted to the other tires as a result.
Locking differentials are a useful feature to have even if you're never going to go off road. I had a Wrangler with locking differentials. I was driving in a snow storm (on top of icy roads) and even the manual 4x4 wasn't enough to get me up the hill. And the Jeep had the computer run traction control. With 4x4 engaged and differentials locked I was able to make it up the very slick hill and get home. So put it in the "nice to have but not vital" category at least.
mylittlepony
NYC
95 Jeep Wrangler / 09 TC Series 5.0
I have 2 questions pertaining to the GOAT modes. I've read plenty but have not found these specifics so please chime away.
1. can GOAT modes be selected at random as needed as the vehicle is in motion[on the fly]?
2. if you do not opt for 4A[advanced] traction option, when selecting 'slippery' GOAT, does the transfer case engage 4H or 2H?
thanks
p/s my 95 wrangler got stuck for a spell with high snow[4']. was shocked when opened difs in manual 4x had me use all of my 4 wheeling snow tactics to get out on stock setup/wheels.
i had a lot of practice b/c done it often enough. I'm always in forlocking rear and that's coming from a'city slicker'.
markregel
markregel
Lincoln, NE
Pont Vibe
Thanks for this information. I'm thinking of going with the standard system with rear locker.
BigMeatsBronco
Allan
2021 FE 2 door
The system has clutch plates, not a diff...
Ford Bronco 4x4 system how does it wo Screenshot_20220121-094805_Chrom
Ford Bronco 4x4 system how does it wo Screenshot_20220121-094724_Chrom
