4H/Slippery on Highway
Luke
Minnesota
2023 Bronco Big Bend
How many of you all drive in slippery on the highway? I was always told never go above 45 mph in 4H, but I am assuming that irrelevant with modern tech. First snow in MN today, want to make sure I'm not putting any extra stress on my transfer case. Drove to work in 2H and was not fun!
5GENIDN
Idaho
If you have the advanced transfer case.... Use 4A.....
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
And if you don't have 4A, you probably shouldn't be using 4H on the highway anyway. 4WD isn't going to help you much if you start sliding at 70mph. Don't be one of those people that thinks they can drive in snow with 4WD just like dry pavement ;)
helifino16
Ron
Mount Sinai, NY (Long Island)
4H and 4L should only be used when OFF-ROAD or if you get into a bind and need it to get unstuck. Relying on 4WD to prevent you from getting stuck is like carrying an umbrella to keep it from raining. Use 4WD only when you need it.
What you're driving as a very capable off-road vehicle, not a go-anywhere all weather vehicle.
Be smart.
Luke
Minnesota
Be smart.
Pretty much how I played it. Appreciate the quick response!
PWillette
Parrie
Maine
I don't see the Bronco being different than any 4wd vehicle...On snow covered or wet road I wouldn't have any issue running 4H at a prudent speed.
5GENIDN
Idaho
Well the most important component in this case... or really any case... is the tire selection. Nothing can work... NOTHING, if the tires do not work. You can have the most advanced 4x4 system in the world and it will not do a bit of good if you can not transfer that to the driving surface. And on snow, on the road, you do not need 4x4, you just need good tires that are made for the situation. And no tire is good at all situations. Although all season tires try, they are a compromise.
PWillette
Parrie
Maine
5GENIDN
Idaho
Boy I would! 4H on wet??? hell no! even if the gears are the same ratio they are NEVER perfect. That means either the front or the rear is going to turn a tiny bit more than the other side even when running with open diffs. That creates bind and it is hard on the drive train.
Hard pack ice... okay... as long as there is lots of easy slip. But really it only helps you in acceleration. Does not help in stopping and that little tiny difference between the front and the rear will/can actually create more slippage when turning than you would have otherwise. Then again with the front turning it can help pull around a corner.....
Unless you have a lot of slippage.... (like hard pack snow or ice) I would not use 4H.....
PWillette
Parrie
Maine
To each his own I guess. Over the last 40yrs of driving I've driven Ford, GM, Dodge, Yotas, Nissans, Jeeps and Land Rovers on wet pavement w/o issue. The Rovers (Defenders & Discos) are full time 4wd (not AWD) and no issue on dry pavement except tire wear.
5GENIDN
Idaho
Well I guess I just believe that I do not want to put the additional bind on my driveline.... Having worked as a mechanic, taught gear design at the university, and 40 years of driving in the rockies.... I just do not like the extra wear and bind for essentially very little benefit.
But like you said, to each his own.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
the disco's and defenders are operating with the center diff unlocked (full time 4WD aka AWD) until you pull the center diff lever.
the big bend is either 2H or 4H. 4H is the equivalent of having the center diff locked.
Either way, i wouldn't operating 4H on the highway unless it was snow covered enough that the pavement wasn’t visible.
