tonesto7
Anthony
Ann Arbor, Mi
2021 F150 Lariat 502A
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dark_widgets_example_v2_1
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dark_widgets_example_v2_2
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) light_widgets_example_v2_1
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) light_widgets_example_v2_2
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
    Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dashboard_menu_example_1
    Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) dashboard_menu_example_2
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
JediMcMuffin
Tommy
2021 Bronco Badlands
I cannot for the life of me get the large widget to work, but the medium and small do. Any tricks?
Herbie
Alex
Cleveland OH
2022 Badlands
Description:
What's New in V2:
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
    • Widget updates
    • Deep Sleep Mode
    • Firmware Updates
Updating from v1:
Giving Thanks:
Looks awesome for all Apple users. Good work. Android user here, my loss.
RunninRiot
Brock
Boulder, CO
“Hey Siri, start my Bronco.”
RunninRiot
Brock
Boulder, CO
Yep. This widget combined with the Siri shortcuts (available elsewhere) mean that I rarely use the FordPass app.
Wait, really?! I was kidding. I just googled it and it is a thing. Mind = blown. I guess I’m taking the rest of the day off to set this up. Thanks.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
I also can't seem to get the lagest widget to populate. The middle size works properly. Thanks for all your work on this!
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
^^^This^^^
How do I make a Siri shortcut to start the Bronco? I could only figure out how to make her open the widget in the scriptable app.
