37" Tires on Sasquatch ?
mljohnson1973
Has their been any confirmation that you can swap out 37" tires on a Sasqustch without a lift or any other modification. I have seen alot of speculation and rumor but just curious if we have any solid information that they will.
Since we are all in a holding pattern for getting our Broncos just trying to plan out my personal build and budget so would appreciate any info you all got.
Thank You
Raptor911
Raptor911
Broadlands, VA
Not possible without a lift. In Moab, there was a video where it was said you need 2 inch lift. I will post the video if I can find it.
cmcbronco
Illinois
2012 f-150 FX4
I think most people agree that it will need a small lift to clear 37” tires. I could be wrong. Or maybe you just need a sawzall 🤷‍♂️.
rlynch356
Rob
Apex NC
Defender 90, RRC TDi, 200 series
I think the short answer is we don't know yet. the 4WP build used a non SAS bronco base and had a 2-3.5 lift. So that's not a direct comparison.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
The video said 2in up and 2in out. I'm curious if the 2in out would really be necessary. It would be nice to throw a small lift on and use the stockers with 37s.
Erock
US
2018 F150 Alpine edition
I think they’ll fit without a lift... just use the fenders as the bump stop... and it’ll probably make a 3 point turn into like a 9 point 😉
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
The 4wp rig was using aftermarket rims with the same offset as the Sas rims so it looks' like 37s will fit without having to stick them out. No idea what that does to turn radius though.
It seems likely they'll need a lift of some sort. The 35s on the non-sas Overlander rig were absolutely stuffed in there.
Trueblue2296
Adam
Tennessee
2021 Badlands, 2022 F250 Tremor 6.7L
There was a ride along form Super Cel East with Shelby Hall. She confirmed that 37 would fit on a stock Sasquatch Bronco. outside of actually doing it, it's all speculation up to this point but I'm hopeful that it's possible. That'll be the first thing I do when i need new tires.
BlueBronco
DFW
Some out is going to be needed so the tires don't rub on full turn. Now, the Squatch wheels may have enough backspacing already. We need someone to view a Squatch in person and have them turn the wheel lock to lock and measure how much room is in front and behind the tires. It seems like someone should have done this already...
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
I'm gonna go with a 37 X 11.50 on BL. I hope it will need minimal lift with the slightly narrower tire as long as the offset is right at the time. Gotta get my hands on it and see how much room there is.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
Can someone please tell me what "fits" means. In my eyes for 37s to properly fit, the suspension should be able to fully compress and extend with minimal to no rubbing. On the 37" equipped broncos I've seen it doesn't really seem like the suspension has enough room to fully compress, especially the front without blowing off the fenders.
395N
Orange County CA
22 Jeep Rubicon XR
I don't see 37's fitting on Sasquatch without additional lift and not rubbing while stuffed off road. For the mall crawler types it might be ok'ish on road, maybe.
BlueBronco
DFW
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
Who makes that tire in a 17?
jay-rod427
Jerod
KS
Ridge grappler in an 18" wheel. Sorry should've included that. I meant Badlands suspension, not BL wheel.
