23S48 / 23V598 (Rear Camera recall)
RoverDude
Maryland
2021 Bronco (First Edition)
Does anyone have Ford's documentation on the steps for this recall.
I'm curious with the shop documentation/PDF is for the recall.
Any help or information would be appreciated.
Ninjak
Miami
No steps in my letter, just a notice to bring it in, and that Ford dealers have been authorized to change it.
Since I changed my cable with the TOR piece, I have not had any camera issues. So until I do, I will disregard this recall.
Ducati1098
Is this what you’re looking for? Or are you looking for the technical instructions? It’s just simply replacing the rear camera.
Ford Bronco 23S48 / 23V598 (Rear Camera recall) IMG_3023
RoverDude
RoverDude
Maryland
I guess what I am looking for is the shop's instructions on this.
It's been a few months since I took of the tire carrier. I can't remember how the camera is attached to it. (I am assuming they would need to take if off to access the camara from behind)
If the camera is replaced, do they have to roll out the mats and recalibrate the 360 cameras?
Looking for info/ step that are to be taken.
Ducati1098
Yes, the spare tire carrier needs to be removed. I attached a PDF for the instructions. The mats aren't required for the Bronco 360 camera calibration, it's just an FDRS procedure that needs to run.
RoverDude
RoverDude
Maryland
That is literally what I was looking for!
I assume the mats would be used.
360 cameras that got right now are slightly off.
I never tried to recalibrate them in FDRS, as I did not have the mats. (Again, I just assumed they were used)
Thanks again!
Ducati1098
Thanks again!
No problem at all. The mats are only used for a select amount of vehicles;
2015-2020 F150
2017-2019 F250-F550
2018-2020 Expedition
2016-2018 MKX
2017-2020 Continental
2018-2021 Navigator
2019-2023 Nautilus
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Thanks again!
Pretty much from 2021 forward all Ford vehicles use a driving method to calibrate the 360 degree camera. It can be a little bit of a hit or miss procedure but way better than using the mats.
Dantastic
Daniel
Lake Saint Louis, MO
www.youtube.com
OBX Sas Bronco, Mazda CX-5
Whelp, looks like this issue is now being recalled for at least 2023 Broncos. I just got this notice today:
Apr 28,2025
Manufacturer Recall Number23S48
NHTSA Recall Number25V273
Recall StatusRecall Incomplete, remedy not yet available
SummaryYOU MAY INTERMITTENTLY EXPERIENCE A REAR CAMERA BLUE OR BLACK IMAGE ON THE SYNC SCREEN WHEN THE VEHICLE IS PLACED IN REVERSE. ONCE DISPLAYED, THE REAR CAMERA BLUE OR BLACK IMAGE MAY PERSIST FOR THE REMAINDER OF THE IGNITION ON CYCLE. ONCE PRESENT, THE ISSUE IS LIKELY TO REOCCUR ON SUBSEQUENT KEY CYCLES
Safety RiskTHE LOSS OF THE REAR CAMERA IMAGE, WHILE IN REVERSE, INCREASES THE RISK OF A CRASH.
RemedyPARTS ARE NOT AVAILABLE. FORD MOTOR COMPANY IS WORKING TO PROVIDE PARTS FOR THIS REPAIR. WHEN THE REMEDY BECOMES AVAILABLE, FORD MOTOR COMPANY WILL NOTIFY YOU VIA MAIL TO SCHEDULE A SERVICE APPOINTMENT WITH YOUR DEALER FOR REPAIRS TO BE COMPLETED FREE OF CHARGE. THE REMEDY IS ANTICIPATED TO BE AVAILABLE STARTING 4TH QUARTER 2025.
Manufacturer's NotesIF YOU HAVE ANY QUESTIONS REGARDING THIS RECALL, OR BELIEVE ANY OF THIS INFORMATION IS INACCURATE, PLEASE CONTACT FORD DIRECTLY AT 800-392-3673 OR LINCOLN AT 800-521-4140.
DemonGT
Dan
Wisconsin
2022 Badlands
Mine is a 2022 and it shows this recall in my ford pass app.
rwm01
Bob
2015 Roush RS1, 2023 Renegade, 2004 F350
As is mine . . .
