23S48 / 23V598 (Rear Camera recall)
RoverDude
Maryland
2021 Bronco (First Edition)
Does anyone have Ford's documentation on the steps for this recall.
I'm curious with the shop documentation/PDF is for the recall.
Any help or information would be appreciated.
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
No steps in my letter, just a notice to bring it in, and that Ford dealers have been authorized to change it.
Since I changed my cable with the TOR piece, I have not had any camera issues. So until I do, I will disregard this recall.
Ducati1098
Is this what you’re looking for? Or are you looking for the technical instructions? It’s just simply replacing the rear camera.
Ford Bronco 23S48 / 23V598 (Rear Camera recall) IMG_3023
RoverDude
RoverDude
Maryland
I guess what I am looking for is the shop's instructions on this.
It's been a few months since I took of the tire carrier. I can't remember how the camera is attached to it. (I am assuming they would need to take if off to access the camara from behind)
If the camera is replaced, do they have to roll out the mats and recalibrate the 360 cameras?
Looking for info/ step that are to be taken.
Ducati1098
Yes, the spare tire carrier needs to be removed. I attached a PDF for the instructions. The mats aren't required for the Bronco 360 camera calibration, it's just an FDRS procedure that needs to run.
RoverDude
RoverDude
Maryland
That is literally what I was looking for!
I assume the mats would be used.
360 cameras that got right now are slightly off.
I never tried to recalibrate them in FDRS, as I did not have the mats. (Again, I just assumed they were used)
Thanks again!
Ducati1098
Thanks again!
No problem at all. The mats are only used for a select amount of vehicles;
2015-2020 F150
2017-2019 F250-F550
2018-2020 Expedition
2016-2018 MKX
2017-2020 Continental
2018-2021 Navigator
2019-2023 Nautilus
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Thanks again!
Pretty much from 2021 forward all Ford vehicles use a driving method to calibrate the 360 degree camera. It can be a little bit of a hit or miss procedure but way better than using the mats.
