2.3 blown engine possible ?
jitsujohnny
Johnny
Latrobe
2021 ram trx, 2022 bronco
So my 2.3 has been nothing but problems since I got it after one week A/C quit working it was a sensor no biggie vehicle down a couple days. I drive 50-100 miles a day no problem first road trip I went on after about 2 hours on the hi way it goes reduced engine power tells me to service engine I checks all the fluids everything is good start it back up it’s running fine again it was a short road trip so it seems it was just a malfunction on the way home it happened again I got home and while I was waiting for an appointment it didn’t happen anymore In the mean time a couple weeks later my low oil pressure light comes on I get out check the oil everything is fine calls the dealer they tell me to bring it in right away so I did and they tell me it’s just a sensor no biggie and that will fix both problems I’m having a couple weeks later I’m on another road trip same problem reduced engine power gets the vehicle back home and my low oil pressure light starts going off again kill the car for a few minutes and everything is fine just now has a service engine light I had an appointment to bring it in Monday Saturday the low oil pressure light comes back on only this time with a power loss and what seems to be some engine noise that shouldn’t be there. It’s at the dealer now has anyone else been experiencing similar issues
Lowcountry Bronco
William
South Carolina Lowcountry
Didn't some of the 2.3s have turbo issues? I'd start a search with that to see if others had the same problem.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Wastegate actuators were corroding/seizing. Nothing like what OP is describing
PWillette
Parrie
Maine
Engine noise doesn't sound good. What was the oil pressure reading when the low pressure alert came on?
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
Sounds like electrical to me.Bad plug, Harness,Bad connection,ECM.....
Lil Red Broncette
Explorer
Two thoughts come to mind.
One, checking oil level does not verify pressure and when I see a low oil pressure indicator I consider that a must stop the engine now situation and tow it in unless I somehow can independently verify oil pressure. Did your dealer have you drive it in that first time or ask you to have it towed?
Two, odd random problems can occur from bad electrical connections. There has been cases of hardware not fully tight at the fuse block under the hood causing all sorts of random things. Since these are all computer controlled, bad grounds can mess just about anything up.
Ducati1098
There is no oil pressure gauge. Only a low pressure warning light.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Johnny. Can you send us a DM with your VIN and dealership info? I can look into this for you.
SPITmadFIRE
CA
@jitsujohnny did you try tightening up the engine bay fuse panel grounding bolts? This was a common problem folks encountered on delivery. So much so, that a lot of us brought ratchets to the dealership to tighten these bolts before we drove away LOL
credit to @Ksjrb03 for being our in-house "TIGHTEN YOUR GROUND BOLTS" ambassador
Ford Bronco 2.3 blown engine possible ? 1673296092584
Ford Bronco 2.3 blown engine possible ? 1673296101201
jitsujohnny
Johnny
Latrobe
I have a base model there is no oil pressure gauge which is weird
jitsujohnny
Johnny
Latrobe
Dealer wants me to pay them to change the oil for an oil consumption test oil was changed 2000 miles ago and they want me to pay them to diagnose my car
jitsujohnny
Johnny
Latrobe
No oil or low oil would absolutely cause low oil pressure. And it was towed in
Lifeliberty
Moonbeam👀
Columbus, OH
That's messed up. You shouldn't have to pay for warranty work
Good luck
Lil Red Broncette
Explorer
Agreed low oil can certainly cause low oil pressure. The point I was getting was the reverse case which is good oil like you had. Just that good oil level doesn't mean oil pressure will be good.
Lil Red Broncette
Explorer
Neither my base nor black diamond have oil pressure gauge. Doesn't surprise me because my other ford vehicles have fake pressure gauges hooked up to a pressure switch. When pressure is high enough to trip the switch (greater than 5 PSI) the fake gauge shows pressure exactly in the middle of the range. I rather have a big red idiot light than the fake gauge.
It would be nice to have a real gauge, but car manufacturers don't like to have real pressure gauge because of how pressure varies so much based on RPM and engine temp.
I would think with all the sensors these days they actually measure pressure. If so it should be readable via an OBD2
