Status
Not open for further replies.
suparee
Renee
CA
suparee.com
Jeep Gladiator JT
After spending more time on the trails, most of us probably have a story where things didn't go exactly as planned.
Maybe it was getting stuck, forgetting something important, or learning the hard way that a little extra preparation goes a long way.
What's the biggest lesson you've learned from off-roading?
Ford Bronco What's the Biggest Lesson You've Learned Off-Roading? DSC01509
rdg04578
Everglades
Bob
Northern Maine
2013 jeep rubicon, F-150
Everglades
A Bronco with 35's is not the same as a Jeep with 35's. The rear trailing arms seem to find things to hit--Jeeps you issue is generally the differentials and those are far more predictable.
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
Don't go out alone.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
If you don't know what you're doing, find someone who does and follow them... as long as they have a similar rig (2dr > 2dr, 4dr > 4dr, Braptor > Braptor or at least a 4dr). Take it slow, don't get in a hurry. Get out and walk the scene of the crime the obstacle you're about to try. Listen to your spotter. Learn to feather the throttle, use manual mode downhill, be skeptical of using front lockers and trail turn assist.
HalfmuleFarmer
Thomas
2025 Badlands
Walking the obstacle, or even a good portion of the trail ahead = ABSOLUTELY. I’ve saved my butt a couple times with a 15-minute walk. Sometimes a trail is totally gone and impassible and going backwards isn’t going to happen. When things look sketchy, check it out. Sometimes OnX is not as accurate re: trail conditions as one might like. ;-)
Oldhippie
Barry
Santa Cruz, Calif.
Don’t be “that“ guy/guys…it is about enjoying your time…
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
I learned don't left foot brake in reverse in 4 Low on an obstacle. I broke a CV axle shaft on the Rubicon trail last month doing that.
Status
