WOLFBOX - G900 - Just a Simple Review :)
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I used this for a few weeks to really give a proper review. There are so many videos out there and unboxing/install guides on this already. Although, I will point out how EASY this is to install. The "hard-wire" kit makes it so easy to tap into your fusebox. No cutting or splicing at all. I even removed the stock Bronco mirror and the supplied bracket just let me slide this on :thumbsup: :bandit:
This is my daily usage review of it :)
First off - the quality of the screen is so good that it was very distracting in the beginning. Almost like I had a movie playing....LOL. It has really great brightness & exposure settings so once you fine tune it, you'll be good ;) It records on ALL screens at all times and will AUTO-lock if there is an incident - so you have a capture of the video/pic at that very moment. Unlike other systems that just mindlessly erase/record on a loop, you can select how these functions operate. Very cool!!
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) IMG_1479
Night time detail. That's my spare tire at the bottom of the picture. While this is an exterior cam, I chose to install the rear camera inside. No lens cleaning required and I pretty much always have a clear view - when the rear window gets dirty I just turn on the wiper and tadah!!! #clarity.
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) 1764091778184-wc
What is also really amazing and SUPER USEFUL with this system is the "voice commands." They make using it safe and not adding anther distraction or "button to press" inside the vehicle. I can toggle between the front camera and rear camera with ease and turn on/off the system if need be. All verbally. It's so useful and very intuitive. I took this shot below when a killer sunset came up....I just said "take picture".
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) 1764091822282-49
Here's another shot that emphasizes how good the quality of the picture is. You can also zoom-in/zoom-out and pan the camera up/down to adjust viewing angle. It takes a little time to set actual distance and my depth perception of things. The adjustments are fantastic and make the whole driving experience safer!
Even in very very low light the camera does a very good job of using the light around it to sharpen the image. Here are some shots in TOTAL darkness in the desert. No streetlights and only headlights of other vehicles.
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) 1764091916505-y3
I was returning from my Mountain Bike ride in the desert and was slowly coming back into town and some light traffic. This shot below just shows how good the camera adjusts to changing conditions.
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) IMG_1540
All in all - I will say that it is completely worth the money. One of the very few things that delivers when it come to $$$ = promised tech. Talk about how things progressed from 3 years ago....There is currently no other dashcam on the market that is this good!!!
https://wolfbox.com/pages/find-your-perfect-dash-cam
Draughon
Daylon
Dallas
BMW 4-Series
+1 on the screen being distracting at first... I was paranoid I was gonna be looking at the front camera feed while driving and accidentally hit something...
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
This is also why I LOVE the voice commands. Like I REALLY need another screen to tap!
NORCALGXP
Sacramento, California
2017 Raptor
@SROC3
Can you post a photo of where you installed/mounted the rear camera inside? Thanks.
Excellent review.
NC_Oak
2024 4 door 2.3 sasq
mine went through a phase where "turn screen off" would not work. no matter how loud / clear I said it, with no other noises to interfere. I got really used to hitting the orange button to turn it off.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Yeah i think that was a previous issue and they had a software update for it that solved it. Mine works great, I just can't have any noise in the background.
Bellime
Keith
2022 Ford Bronco
I like mine also, but what I found when I first started was that the glass was super reflective which made for a confusing image, once I applied the anti-glare film, problem solved.
It freaks new passengers out when I grab the mirror and move it to show them, my wife no longer has to adjust that mirror.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Huh? What anti-glare film??? It comes with that or did you buy separately. I had to tilt away from rear and adjust.
Bellime
Keith
2022 Ford Bronco
I think they have it now available, but wasn’t available at the time, so I used some that was left over for a laptop.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
@SROC3
Excellent review.
Thanks man and here are the shots. I not only drilled holes for the screw (only used one in center of bracket), but also applied some double sided tape as well behind it. Hope that helps! :)
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) IMG_1548
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) IMG_1549
NORCALGXP
2017 Raptor
Excellent I like this inside. Thanks for the images and info. Happy Thanksgiving
Bellime
Keith
2022 Ford Bronco
I used parts and pieces to make a base to mount the camera to. I have no problem with visibility and vibration. Similar solutions seem to show and opportunity for someone to make a better bracket
Ford Bronco WOLFBOX - G900 - Just a Simple Review :) IMG_2483
