Wiring tape Engine area
Chicago
bronco outerbanks
Just want to get the forums opinion on these 2 pictures.
Noticed that the tape does not cover wires close to the connector. I’d assume the tape (especially the silver thermal tape ) was protecting wires from engine heat. Look forward to comments.
Ford Bronco Wiring tape Engine area IMG_0862
Ford Bronco Wiring tape Engine area IMG_0863
Ford Bronco Wiring tape Engine area IMG_0861
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Looks pretty standard for automotive wiring harnesses, not that it's ideal.
If you're concerned about it you could use a high temp electrical tape, but it's temperature limits are in the 360 F (H range).
Ford Bronco Wiring tape Engine area 81jkhxr5yDL._SL1500_
The insulation is there for where the wiring crosses hot stuff, or the black friction tape just to keep the bundle clean and from getting rubbed/cut by corners. The connector isn’t at a hot location - otherwise the plastic connector would be insulated too, or moved to a cooler location.
Feel free to tape it up though if you want it to look better
Russ.Cere
Russ
modcrate.myshopify.com
Yo, Chief no work without a reference.
NAVAIR 01-1A-505-1
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Welcome to the Ford Motor Co. There is little doubt that some bean counter calculated how much they’d save by eliminating a couple extra inches of electrical tape at the ends, and it was approved. I’m still a bit stunned at how they terminated the aux switch wires.
