Windshield Wiper Fluid Pump Issues
Yeti II
Sam
Nashville, TN
2021 Ford Bronco Big Bend 4 door
Mine stopped too and it was the pump. Ford replaced it . Took a bit a its built in to the panels but it's working fine now. Fingers crossed it stays that way....,
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I really hope they have the part on hand and I don't have to come back. It's 45 min drive each way. Scheduled for next Tuesday.
F1NDx
Detroit, MI
@redone17 This happened to me the other week. Oddly the fuse was blown, not the pump. Check that. Might save you the time.
redone17
Cold Spring, NY
@F1NDx - will do! Thanks.
Silver-Bolt
Eureka, MT
Long shot. Is the tank vented? I had an issue on a previous vehicle where the washer would work a little then just barely dribble. It turned out that the tank wasn't vented and couldn't draw in any air. Try it with the cap open on the reservoir. Worth a shot.
redone17
Cold Spring, NY
@F1NDx - no such luck. Looks fine visually. Swapped it with the rear windshield wiper (which I don’t even have the prep kit) - still nothing.
redone17
Cold Spring, NY
So, I had to pick up my truck after service was closed - so, I’ll call and get the full story in the morning - but, from what I can decipher from the notes is they removed wheel, wheel liner, reservoir and then installed the new pump and that did nothing. Ended up taking the wipers and the cowl off and finding a pinch in the hose. Flushed it and then it was fixed. That’s a lot of free warranty hours for a $40 part! I would have been livid if I did the work myself. It’s certainly worth having to go back to the dealer that’s 40 min away - twice - because they needed a tech to assess the problem before ordering any parts. Guess he/she didn’t assess well enough upon the first inspection.
How/why would that happen after 16 months - who knows?
Amcole1984
Amber
2021 2 door Bronco Big Bend
Yep, it happens. We’ve had several instances where we thought we were out of fluid. Something wrong with the design, for sure… 🙁
Same. Happens to me intermittently. The washer fluid also needs tobe pretty full all the time. It doesn't work very well if it's wven a little bit low.
redone17
Cold Spring, NY
I'd check for a pinch in the hose like I mentioned above.
jalawson
TX
‘22 Bronco, ‘17 F150
redone17
Cold Spring, NY
Where was your pinch at?
They said under the cowl. Seems odd to me after it worked for 16 months. But, zero problems since.
‘21OBX
90Bronco19
2022 bronco outer banks
For anyone else check fuse #16 in the under hood fuse box. Ours quit when it was in the neg temps. I even tho I always buy quality -25/-30F fluid. I thought oh well it froze. Well we got back into the upper thirties. And it still didn’t work I went looking around and found the fuse was blown.
Ford Bronco Windshield Wiper Fluid Pump Issues IMG_2979
FifthCard
Allen
US
Jeep Wrangler Rubicon
Just had my pump go out. Took forever to get dealership to even get me an appointment. I have a 21 with 33k miles so worried about it before warranty. They told me it was a wire that got pinched in the fender well somewhere. Going to replace it this time under warranty but tried to say it was my fault. I do have an ARB compressor and winch mounted with wires run to upfitter switches and has been that way almost since the day I got it over 2 years ago. I have never once messed with the fender area so don't see how that was the issue.
It seems when anyone adds aftermarket they blame you for anything.
redone17
Cold Spring, NY
Shady dealer doing shady things.
Miner
2021 FORD BRONCO BADLANDS ADVANCED
I had the same issue. Blades would swipe but not washer fluid came out and no pump motor sound. I replaced the fuse (10amp, slot 16, interior) and everything is back to normal!
Note: in my 2021 Badlands Bronco, the cabin fuse box is located below the steering wheel. Have to pull down the panel (panel swings down on hinge pulling from top) to access fuse box. This is not where my manual says it's located.
