Window Switches - Should they be Switched
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
I put a clear cabinet stick on door stop on each of the front window switches. That way at least they feed different. Not my ideal but does help.
Bobio
Bobby
United States
2024 Bad lands
It’s a new learning process I guess, but I’m with you. I think they’re backwards. I always thought that the most important movement should be closest to your hand. Say a light switch in a dark bedroom, it has 1,2,3, even 4 switch box. I went though my home and lined them all up to importance. I reach my hand in a dark room I want the main light on the first switch that my hand comes to, second light the next light (accent light), fan light is next and fan speed last. I know, I know, it’s stupid. Those are in order of how often I use the functions in that box. Looking down on the window switch it’s correct but if my hand is coming down on the switch it’s backwards. First two should be driver and passenger and the next least used, should be below that. Lol
It’s just my dumb ADHA I guess. lol. 🤪
Bobio
Bobby
United States
2024 Bad lands
You should de my fridge. F*+’, I need help.
Area51_BADLANDS
Toronto
2023 Heritage Limited REB
The switches should use a normal setup in all the doors instead of the center console.
Ford really saved a lot by eliminating the extra switches a normal setup uses. Great job ford.
I think they did not want two sets of switches, added electrical wiring and potential for interfering with each other. Do agree that an option to reverse switches would be good. It seems intuitive to use the first 2 buttons (lower set) for front windows. Probably need to cut to fix as usually modules !
Area51_BADLANDS
Toronto
I've put a decent amount of ass time in the seat of the Bronco and I have to say, I am still lowering the rear window most of the time before I realize I have my finger on the wrong button, and have to raise up the rear window and then lower the driver window - and yes I go through Dunkin Drive Through way too much.
And yes 2 door crowd, I know what you are going to say. 😒😁
So I'm wondering, has anyone flipped the switches to put the front windows on top and the back windows on the bottom?
And am I the only one who's brain refuses to get on bord with the switch positioning? :oops: o_O :unsure:
I think if you did a survey you would find that most of us have opened rear windows by mistake when intending to open fronts. lol
Hbarr
Harry
West Grove,PA
2023 Ford Bronco & 2015 Dodger Challenger RT
I've been saying that all along the switches should be switched. I make the mistake every time.
adam1991
VW GTI (2)
Thank you for not calling that a "hack".
DriveAllNight
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I’m still gone say it….. Whinny ass Moor Door drivers just complain and complain about their lifted Explorers.
ahahahaha
No crowd whines more that 2 door Bronco owners, especially when someone makes products for 4 doors and not the 2 door Broncos o_O 😁:eek:🤣😂;):LOL:
With that said, I wish I owned both but that's not reality for me.
adam1991
VW GTI (2)
ahahahaha
products like, the 2.7...
29AGAIN
Marty
ATL - ITP
1929 Ford Roadster, 2019 Tesla MS, 2022 Bronco BB
great minds … as they say!
My issue was not remembering which pair controlled which windows, but rather both pair of switches FELT the same.
Ergo, the stick-on bumpers worked the trick. Totally effective, cheap, removable, available in different colors, shapes, and sizes, yada, yada. Works for me 😎
29A
Ford Bronco Window Switches - Should they be Switched IMG_0086
skhubbard93
Saratoga NY
'21 Badlands, '01 Z8
I wish Ford had provided a tactile difference between the front and rear window switches for the driver. Like maybe use the switches with the rounded-ridged ends for the front, and the smooth for the rear. I understand why they didn't - cost and assembly complexity - but it would have been helpful.
When I operate them, I have to feel both sets by "braille" and then use the desired controls. If I just rest my forearm on the console and hit the switches, I get the rear ones every time so that isn't helpul.
adam1991
VW GTI (2)
no automaker does this, frankly because there's no need to--the tactile difference is already there with respect to position relative to each other.
you'd rather they be stuck behind three levels on a touch screen?
I can't remember the last time I DIDN'T feel the switches and their relative positions on any car of mine in order to choose the correct switch. It takes about half a second.
KABQ
Aaron
Albuquerque, NM
If it's really bothersome, why not just re-pin the connector? It would take about 2 minutes once you know which wire is which.
29AGAIN
Marty
ATL - ITP
Do you mean we should not modify our Broncos differently than how our manufacturer, in their wisdom, has provisioned them? Good to know.
Boy, am I ever doing it wrong!!!!!!
