Window not dropping for door opening
foreWard
Ward
RVA
2022 Badlands
Just noticed today that my left rear window isn’t doing the drop/raise thing when the door is opened/closed. I think it has been like that for a couple days because it had been making a weird sliding noise the couple times I opened it over the past week, but was always in a rush and didn’t investigate. Then I figured it out this morning.
Any ideas on how to reset it? It doesn’t really affect anything other than I have to close the door harder to overcome the resistance, but it can’t be good for it long term.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
foreWard
foreWard
Ward
RVA
2022 Badlands
  • Like
Reactions: Cat
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this window concern on your Bronco. Thanks!
EN2DIRT
Randy
SoCal
2022 Bronco Badlands, 2021 Jeep Gladiator Rubicon
I've had my Bronco only a couple of weeks and had problems with front passenger window. When I roll it up, it immediately came down. Did this a few times in a row then stayed up. Went out the next day and the window was all the way down which is not good since we are finally getting some rain her in SoCal. So annoying on a brand new vehicle. I was hesitant about buying a Ford but my wife really wanted this Bronco. Ugh!
Chisox0508
Ryan
Atlanta, GA
I had the same problem, I searched the manual and it’s known as the window bounce-back feature. I guess somehow it may have gotten disabled, but to reset it, when you lift the window hold the switch up for 2 seconds after it reaches the top. It should then reset.
(If you want to see it in the manual, search window and go to “Override Window Bounce-Back)
BigHoof
PA
Ram 2500
How well are these windows working out in the cold weather most have been having lately? We had rain then temps with the wind to almost -40 F below zero just before Christmas. Could not open the windows on my car even after driving with the heat on for about 2 hours. What happens with the Bronco doors in those conditions? How do you open or close them without breaking the window since they can't move? I have owned several cars with frameless windows over the years and none have had or needed the drop feature.
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
I had one completely drop at -10. Opened the driver rear door and the window hung up. No movement at all. Noticed as when I closed the door, the glass was stuck on the outside of the seal. Thought I was going to shatter the glass. Opened the door again and it dropped all the way down. After driving a Honda for a few years, I was dead sure I was going to have to replace the regulator. But it rolled right back up and have had no issues since.
My passenger rear is another story. It drops way too slow and hangs up every time. Closes just fine, but it's very noticeable when opening. Hot or cold. I've done the soft reset (buttons) and hard reset (pull power while moving) and it still is messed up. Dealer brushed me off when I wanted to get it checked out when doing the hardtop recall.
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
Window reset should fix it. But I hear you… frustrating on a brand new and $$$ vehicle
Ground_zero298
Scs michigan
Silicon spray for rubber seals in the winter. Will definitely help. Can also put some ceramic coat around the first inch of the inside window edges too.
EN2DIRT
Randy
SoCal
I performed the window reset last night. Fingers crossed it works.
Fly
MA
Subaru Outback
Is a normally functioning window supposed to lower itself an inch or so when the door opens and roll back up when the door closes?
EN2DIRT
Randy
SoCal
Yes, it lowers to be free of the rubber seal when opening and when you close it, it rises to push up against the seal to be water tight since there is no upper window frame on the door.
  • Like
Reactions: Fly
