Window not indexing / dropping down when opening
Kbeas
Ken
New Jersey
Suggestion… can the window be programmed to index down when the handle is touched, rather than when pulling on it? The unlock feature and the window indexing down could be done together. If the door isn’t opened, the window/s returns to the up position after a timer is reached. This could also work when using the key fob when unlocking the doors. Which I swear it used to now doesn’t.
foreWard
Ward
RVA
2022 Badlands
Hi Ward! I can look into your Bronco's window concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
I'm good now, the 2 second hold process worked like a charm.
