Will it Rub? 37s 13.5
Raskits
Carlo
2022 Bronco, 2021 BMW M3comp, 2022 Tesla
Hi everyone,
Need some advice. Planning to mount Toyo Open Country 37s to the stock Sasquatch wheels with 1.5inch spacers. I have a Bronco Sasquatch w/2.5 RC lift.
Hoping to install 13.5 wide instead of 12.5 if possible. Any concern for rubbing with 13.5? Should I stick with 12.5 wide?
Ford Bronco Will it Rub? 37s 13.5 20230413_191634
PWillette
Parrie
Maine
Hi everyone,
I don't have 1st hand experience but there was a post awhile back w/ someone running 37 x 13.5s. If memory serves they were on a zero offset wheel on 3" lift and were rubbing both the crash bar mounts as well as the fender wells.
Baja Bronco
2Sun AZ
I run Toyo RTs, 37 x 12.50 x 17, 0 offset. I stayed away from 13.50 due to there just isn’t a lot of room in there. People might run them, IDK. I don’t rub though, Icon Stage 8. I’d recommend 12.50, if nothing else, cheaper tire.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
With a little trimming they fit. As @Snacktime said trim the front body mount and remove the plastic block behind the front fender well. Also you need to trim the factory rock sliders 1”.
Ford Bronco Will it Rub? 37s 13.5 4BF797DC-554A-4DE6-AE50-EF843690A3D2
Ford Bronco Will it Rub? 37s 13.5 7F1E5F40-9C03-4892-B863-E91CFE6AA605
Raskits
Raskits
Carlo
Thank you for this info! Which one is the plastic block you are talking about?
SS Bronco
Shayne
Loomis CA
Back side of front fender is a honeycomb shaped plastic block, behind the liner no sure of purpose. The JKS max tire clearance is basically what I did, now that’s it’s available it is the way to go.
Baja Bronco
2Sun AZ
You will need to cut the front body mount up. Then remove the rear crash bar bracket.
I’m not trying to stir the pot, but I didn’t do any of that, and I don’t rub. Might be the Icon Stage 8? I saw a thread awhile back that a member had cut his front body mount. Loved the way it looked, didn’t love that he told me it would void my warranty.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I run 37x12.5 and didn't rub at all when first installed. Now I am rubbing all over the place. Just give it time 😉
PCDan
Dan
Park City
1968 Ford Bronco
Hi everyone,
Yes it will rub, likely a lot with 13.5. Anyone that tells you otherwise has no idea what they’re taking about or they never drive over anything bigger than a stinkbug and never turn full lock lol … just search the many 37 rubbing mod threads.
Raskits
Raskits
Carlo
Okay I decided to just go for 13.5 wide Toyo 37s M/T. Don't regret it at all. After reading posts for days, looks like even with 12.5 I would still need to do some trimming with 37s. SS Bronco was spot on. Drove it 100miles on first day in the city/freeway. No rubs until backing out and doing full lock. Seems to rub mostly on OEM sliders. Will be cutting it 1in 1/4 and cut both crash bar mount. The honeycomb one is easy hehe.
Ford Bronco Will it Rub? 37s 13.5 20230714_095950
Raskits
Raskits
Carlo
Finally got to cut them. Also took of 1inch 1/4 from rock sliders as well. No more rubs
Ford Bronco Will it Rub? 37s 13.5 20230721_161309
Ford Bronco Will it Rub? 37s 13.5 20230721_161306
SS Bronco
Shayne
Loomis CA
Looks good, glad it worked out for you. I’ve been happy with the performance and the look of the wider 13.5 tire.
Ninjak
Miami
Nice. I run a 37' 12.5 and I am good. No rubbing but as you already know, had to do some stuff. I am also on a 4' fabtech lift.
