When is an engine block heater really needed?
timrobporter
Tim
CA
2024 Bronco Raptor; 2023 Bronco Badlands SAS
Just make sure you put an extra blanket over your Bronco when you tuck it in for bedtime. It should be nice and warm all night long, and not require a block heater.
What kind of blanket do you use for that? Can I order it through the ford website?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I suggest buying a crocheted one off Etsy.
I sure hope you realize my original post was a joke…
Toccoa
Isuzu Rodeo Sport
GroovyGeek
Boyan
'23 Bronco BD
No worries at 0. -30 is a different story. @Sven might be more helpful...
Can't speak for the Bronco but a Wrangler started 4 days in a row in below -40F weather in Calgary a few weeks ago. No real hesitation in the morning after all night outside. No engine block heater. Was really surprised, I was expecting the oil viscosity to go up substantially.
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
I checked the block heater as an option when I ordered the Low-Q Bronco.
$110 option. Well worth the money if you ever need it.
Posted this pic on Fascistbook with the caption "Plug-in Non-Hybrid".
Got a bunch of feces from former frens-of-mine who live in cold country.
It's my money, and my truck...I'll do what I want with it.
Ford Bronco When is an engine block heater really needed? plug-in non-hybrid
broadicustomworks
Hanging Rock, North Carolina
I also recommend crochet. (y)
You know who doesn't?
Because YARN.
I must resist the urge to tag her.
Must. fight. the. intrusive. thoughts.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
I'm from the south, so engine block heaters are new to me. I had the option to purchase a Wildtrak with a heater, but I didn't. Now, I'm heading to Taos, NM for a ski trip where the temperature will be 0 degrees. What is the guideline for when you need or should use a heater?
When it's cold. Or you can use any season. It's not magic.
Aonarch
Jack Hoff
MT
I've never used mine.
Diesels absolutely need block heaters. Gas cars, not as much.
I've read below -4F is when you want to use a block heater.
JerryC
Memphis
2022 Bronco
Watch some of Project Farm's motor oil tests and see what cold temps do to the oil.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
I wasn't aware that they were an actual option.
My '15 Mustang came with one by default, since MN was one of many DSOs on the list that got them standard whether you wanted it or not. I sort of assumed then that this was the case with any newer Ford.
And it definitely sucks here in winter, and I wonder more and more every year why I continue to live here...
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I didn't read the whole thread, but I've never had a block heater and driven many times in sub zreo temps including down to -20 in my '13 mustang GT. I think engine heaters were more important with older, conventional oils that really didn't flow in the cold compared to today's synthetics.
That being said, I got one one my Bronco because I ordered, and for $100, why not? It's very hard to add after the fact from what I understand. I've used it a few times, and it is nice to be able to have a head start on heat in the cold, but I haven't used it in a long time, just not really worth it.
But, going forward, I will always get one if I can, because it might be nice if I really need it, but I wouldn't fret if I didn't have one ;)
dpequip
Pickens, SC
23 Bronco OBX 23 Maverick AWD F350 Flatbed 4X4
Be aware block heaters add a point of failure. Yes I have them in my diesels but I had one blow out because the retainer that held it in the block cracked in half and the block heater blew out dumping all the coolant and yes it put me on the side of the road. According to Ford parts man this was common issue as he had several in stock. If you truly need one get it, but be aware it's another point of failure for leaks.
