Studawg
SC
02 Excursion, 96 Land Cruiser, 18 Land Cruiser
Not sure I understand. Offset number isn't relative between vehicles and only relevant to calculating aftermarket wheels. Ford could have put a +100 on it and as long as the engineering allows for suspension and brake clearance and lines up with the body, it's irrelevant. -55 offset is a pretty good sweet spot for steering neutrality and bearing life. Ford is also bound by regs to not have tires poke out past fenders. Hence the ugly Sasquatch abominations.
To be accurate, its not -55, its +55.
colintrax
Georgia
Chevy Colorado, Ford Explorer, KTM 890 ADV
Be careful with that. A very large percentage of aftermarket wheels are made in China. Ask before you buy.
Oh I know, I always check with everything I buy. But that's good to point out, we probably ought to get a list going of wheel manufacturers. Where they're made, how they're made (forged, cast), cost, and reviews.
Rubisquatch
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
I was looking at putting Toyo AT/III's in 35X11.50R17 on these wheels (just a hair wider than 285s). Looks like I would be fine width wise clearing the arms. Probably will need a 1" or 2" lift to fully clear for diameter.
I was looking at this too but one thing of note is if you order a non squatch Bronco, it will have the crash bars in the front wheel wells and a 35 or 315 will very likely hit those when turning the wheel (even though width-wise with an 11.5 wide yo should be fine) so you’ll have to cut them or remove them As the 35” height would be the issue. Ordering squatch means the Bronco comes with much shorter crash bars to accommodate the 315 tire.
In the below pic is the squatch chassis and I circled the shorter crash bars. These ARE like 6-8” longer on non squatch Broncos. See 2nd pic for non squatch.
Ford Bronco Wheel offset confirmed for optional Badlands wheel (+55 offset) 0FC60350-B265-468A-8A9F-A96AEC372EBD
Ford Bronco Wheel offset confirmed for optional Badlands wheel (+55 offset) 22CBA8D0-0FA7-44CB-A90B-D65BDA8DE94F
RedDawg
Erik
PHX AZ
Crash bars don't come out in front of the tire. They stop about 1 1/2" before the inner plane of the wheel. And from what I saw, easily
Ford Bronco Wheel offset confirmed for optional Badlands wheel (+55 offset) 20201202_161824
removable.
Ford Bronco Wheel offset confirmed for optional Badlands wheel (+55 offset) 20201202_161837
Aman
Aman
Northern NJ
Hmmm, I assumed that the pic of the Sasquatch frame just doesn't have the extensions bolted on. Without the extensions, they are pretty much useless.
Studawg
SC
Crash bars don't come out in front of the tire. They stop about 1 1/2" before the inner plane of the wheel. And from what I saw, easily removable.
Is that true for the rear crash bar as well? It looks like it would come out past the inner plane of the tire, unless it was removed
RedDawg
Erik
PHX AZ
That picture is the rear crash bar for the passenger side front tire.
I couldn't get an angle to get the distance between the wheel's inner plane and the bar.
Best I could get is this
Ford Bronco Wheel offset confirmed for optional Badlands wheel (+55 offset) 20201202_161848
Studawg
SC
Thats a Badlands with the 285s right? Man thats gotta be cutting it close for a 315 when turned. Im thinking maybe Ford made them removable for the squatches and they will come without those extensions?
Cased
middle
dune buggy
Those crash bars look like they might help peel off the red clay we have here in flyover country
Economisto
Houston
2000 Mistubishi Montero, 2013 Audi S5
I need to know if this is a fact. Might mean I should just go 35s from factory to not have to worry about modding those crash bars aftermarket.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
This means a lot more people will be opting for the Sasquatch package.
cost of 5 35" tires, cost of 5 new rims, mods to truck to make them fit = Sasquatch is still the cheapest way to get to 35's
Studawg
SC
I think its just a couple bolts on each to remove them.
