What upgrade would you do if ....
skyhunter
MA
2024 2DR Bronco
So I never thought about a sasquatch package, was not even on any of the vehicles I was looking for (A white 2dr [yes I am that boring] ). I only drive on the beach now and then for surf fishing and also drive on Maine logging roads. If you are not familiar with them they are like gravel highways (logging truck have right of way and bomb down them like they are running shine) but some spots are unmaintained by the paper companies for years will the area grows back and can be rutty mud and rock jacked up strips of fun, especially the one's that are snow mobile trails in winter. NH has some open Class VI roads that a sporty as well.
They way I learned "off road" driving was stay in 2 wheel till you start getting stuck then put it into 4 wheel and go back the way you came. I never had a desire to climb rocks but the Off-Rodeo should be given BEFORE buying a Bronco. LOL
I of course have the trail turn assist button which seems silly for a 2 door, it is the shortest vehicle I ever owned and turns around curb to curb easier than a road king. Anyway I see some have listed their DIY updates for non 765 vehicles on here and the metube. The front stabilizer bar disconnect set up to rear electronic diff. If you were to only do one, which would make the most sense first.
Fordified1
Bob
Mid South Texas
Rear locking diff hands down. Unfortunately it’s the most expensive to do after the fact if you have 3.7 gears.
KABQ
Aaron
Albuquerque, NM
Locker 100%. I don't have the sway bar disco, but the lockers have saved me (and helped me show up my FJ buddy) many times. The sway bar disco won't help you in sand, the locker will save your butt.
Pokey_Cacti
Dan
Prescott, AZ
2024 2-dr Black Diamond
We have a 2024 2-dr Black Diamond, and I'd agree with Fordified1 on the rear locker. We had a 'zuki for almost 20 years, though, no lockers, although now, after going through the off-rodeo and the REAL capabilities of the Bronco, we've used the locker on a few occasions...it's mostly been convenient and not needed, though. I'd expect if you just went as is you'd have lots more time grinning than concerned. Get traction plates for the mud & sand...
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Skid plates, suspension and then some tires! I wouldn't buy into lockers till you blow up the front end. Having less will teach you more, its funny how many people use lockers instead of picking the right line to get through something. Learning were to put a tire is more important than anything you can buy.
Fordified1
Bob
Mid South Texas
You are correct of course, but I thought his question was pick between disco sway and rear locker.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Between those, I will take the rear locker! I still run my front swaybar, wheeled once without it and put it back on.
Fordified1
Bob
Mid South Texas
I broke my front diff when I forgot to re-engage my rear locker and got in a bind in a bad place (think cliff and trees) and tried to throttle out. Brain fart. Happens more and more at my age.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I remember that post lol! A few of us made those m190 last a few years!
totaljustice
Kevin
Middle Sackvegas, NS
If I could afford it, I'd get a matching Hot Pepper Red painted hard top.
GetShifty_Bronco
Shane
25 Bronco Base Sasquatch 2.3L
The front electronic disco swaybar isn't even really worth it after the fact. Just throw an Anti-Rock in the front and call it good. For an either/or situation definitely do rear locker first.
skyhunter
skyhunter
MA
2024 2DR Bronco
6k get the ultimate dana 60..
Advantages over using the M220 in 4.46. I see they have the Dana in 3.73 for 6+ grand. But at Ford parts a rear M220 in 4.46, a front 210 in 4.46, the 2 half shafts and the hook ups and such are near abouts the same for just the Dana rear.
Valhalla
Valhalla
Chattanooga Tn
True, but the 220 is just a metric dana 44... good up to 35's with harsh use (I'm running 37's on mine but I have the UFD and the Ultimate rear coming in a 4.88) I have broken 3 front axles (although I say the first was not my fault).
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
As stated the rear locker. That is the single best improvement that you can make to a base 4X4. Second would be the front locker.
