What are you using for rear cargo inside lighting solutions
RickDeckard
Kentucky
The Quake LED cargo area 39” lightbar!
Is it overpriced: yes
Is it well thought out: yes
Did it ship with cheap splicers I replaced with positaps: yes!
Am I happy!?: you bet your ass I am. My cargo area and everything behind my vehicle when using the tailgate table is extremely well lit.
Thanks for mentioning the Quake LED light. I just went on their website and ordered one.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Thanks for mentioning the Quake LED light. I just went on their website an ordered one.
I'll get you some photos of mine later this evening. I have a soft top and was able route the cabling very cleanly. It sits so flush inside that you can't even see it.
mpeugeot
I just use this... seems to work ok.
Ford Bronco What are you using for rear cargo inside lighting solutions Screenshot_2022-11-10-15-11-58-978
14,000 lumens seems to be enough light.
thatspecialbeat
Ryan
Meridian ID
Subies
Here is my current (lol) lighting project I am working on. Mounted two lights using the roll bar bolts. The light is diffused so it fills the whole cabin well. I have been living with the lights for a couple of weeks to make sure there aren't any issues before I wire it. Still not sure how I want to turn them on and off. I don't want to have to hit the power button so probably no aux switch.
Next project will be to mount one on the lower portion of the hump on the tailgate. That would light up the ground behind the Bronco with the tailgate open.
Ford Bronco What are you using for rear cargo inside lighting solutions PXL_20221110_204009995
Ford Bronco What are you using for rear cargo inside lighting solutions PXL_20221110_204017640
JimboSlice
South Lake Tahoe, CA
2022 Ford Bronco Outer Banks 2018 Audi Q7
I also have a soft top, so pictures would be great! Thanks in advance.
Ground_zero298
Scs michigan
Grabbed a 39” off Amazon. Hooked to power, I have remotes to turn it on and off, or it auto offs when the accessories shut off if left on.
Remotes for a 100 yard range. Hitting lock or unlock will send power to it. Have a remote by the tailgate, drivers visor, and on my key chain.
With it being on the bar itself, it’s never in the way, and it never has to come out.
Ford Bronco What are you using for rear cargo inside lighting solutions 7131BE36-C9AD-4FC9-A87F-CD2EC604F250
DangerMTBBronco
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
2022 Bronco Badlands Sasquatch
Love where you put it. Where did you connect to power?
Ground_zero298
Scs michigan
Easy install. Tapped off the center dome light. Just pop it out and the wires are right there. Put the remote hook up in there too. It won’t work like that light does, but can supply power for it. It fits in that spot on the bar damn near perfect.
Light bar $59.99
https://www.amazon.com/gp/aw/d/B076KR77Y9?psc=1&ref=ppx_pop_mob_b_asin_title
Remote kit. $25.99 These things are the best. Can run about anything 12v with it up to 30 amps
https://www.amazon.com/gp/aw/d/B09MD63LY6?ref=ppx_pt2_mob_b_prod_image
atlawson
Tracy
Rose Hill, VA
Bronco 2022 Wildtrack Lux w/ Sasquatch
Is there any solutions to have the light come on with the doors being opened?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
You should install "The Clapper" to turn it on and off. That just adds to the fun.
I wonder if I can use this to turn on and off my AUX lighting... :unsure:
Ground_zero298
Scs michigan
Touch sensor would be way more fun trying to get back there and turn it on.
Ground_zero298
Scs michigan
@604Bronco
Okay. I’m going to install a clapper like you said. I’m on the fence for Christmas story and Bob Ross, what’s your thoughts?
Ford Bronco What are you using for rear cargo inside lighting solutions D8FF768F-484A-480A-8E97-CB1DC9A005CF
Ford Bronco What are you using for rear cargo inside lighting solutions F84BA96C-D4CA-4E2B-A939-81CE4676D6D1
604Bronco
British Columbia
www.bronco6g.com
@604Bronco
Neither of those are red, so they won't suit your Bronco and therefor aren't compatible, lol.
Ground_zero298
Scs michigan
Settled then. Going with Vader. Will air brush some red highlights on him.
Ford Bronco What are you using for rear cargo inside lighting solutions 1E313B32-13E0-4894-AEB3-A94CB2D9874D
JimboSlice
