What are you using for chase lights?
Pseudoko
Vince
Chino, CA
My 2 Feet
I have had these bookmarked to buy soon :)
Fast Intentions has released our Universal Chase Light Mount aka " The Uni ".
These affix to the spare tire lugs and can be used with most offroad lights allowing for ultimate adjustability and a sleek / low profile look without blocking your entire spare wheel. Will fit with OEM wheels as well as most aftermarket wheels.
BRONCO CHASE LIGHT MOUNT | Fast Intentions
  • CNC Laser Cut from 10ga Steel.
  • CNC formed specifically for 6G Bronco.
  • Durable 2 stage textured black powder coated finish.
  • Optional threaded lugs with hardware for easy installation.
  • Optional locking hardware with safety Torx tool to protect from theft.
Pseudoko
Vince
Chino, CA
My 2 Feet
Rebecca Tiffany
Rebecca
Rancho Cucamonga
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
So we have a few options
Baja Designs Reverse Kit for 2021+ Ford Bronco
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
Ford Bronco What are you using for chase lights? 1709482086925
It's a reverse kit but if you throw some amber covers on, instant chase lights. The lights are controlled from a switch so they don't actually come on automatically when you go in reverse. Available with or without that license plate bracket you see.
Diode Dynamics Stage Series Reverse Light Kit for 2021+ Ford Bronco
https://www.4x4truckleds.com/diode-dynamics-stage-series-reverse-light-kit-for-2021-ford-bronco/
Ford Bronco What are you using for chase lights? 1709482138573
Similar to the Baja Designs kit, they mount in the same manor. However these tie into the factory pigtail for the tail light so they will come on automatically when you go in reverse. They also feature an upfitter connection so you can control them from the upfitter as well. Again, throw some amber covers on and instant chase lights!
2021+ Ford Bronco Reverse Light Kit w/Baja Designs Lights & KR Off-Road Brackets
https://www.4x4truckleds.com/2021-f...t-w-baja-designs-lights-kr-off-road-brackets/
Ford Bronco What are you using for chase lights? 1709482198855
This is our kit that we put together and mounts the lights under the rear bumper. We include a pigtail/harness that connects them to the factory circuit as well as an upfitter. You are not required to do either though. You can do reverse only if you want OR just wire it to the upfitter only. OR do both for 2 way control. Throw some amber covers on, chase lights. The lights are adjustable so you can mount them high/low under the bumper allowing you to hang them down or up close to the bumper. And yes, they are low but you'll break your exhaust before you hit the lights while off-roading, so you won't have issues there.
2021+ Ford Bronco Reverse Light Kit w/Diode Dynamics Lights & KR Off-Road Brackets
https://www.4x4truckleds.com/2021-f...w-diode-dynamics-lights-kr-off-road-brackets/
Ford Bronco What are you using for chase lights? 1709482283101
Same setup as Baja Designs, only with Diode Dynamics.
SDHQ 3rd Brake Light Chase Light Mount for 2021+ Ford Bronco
https://www.4x4truckleds.com/sdhq-3rd-brake-light-chase-light-mount-for-2021-ford-bronco/
Ford Bronco What are you using for chase lights? 1709482345046
This one gets pretty crazy. You've got a pair of Baja Designs lights plus a Baja Designs RTL bar. So you have a little bit of everything. Reverse lights, chase lights, etc... The RTL bar is a Rear Turn Light Bar, so it gives you some added functionality
Baja Designs Chase Light (Suction Cup Mounted) Kit w/KR Off-Road Brackets
https://www.4x4truckleds.com/baja-d...ction-cup-mounted-kit-w-kr-off-road-brackets/
Ford Bronco What are you using for chase lights? 1709482406117
This is a temporary chase light you can install when you hit an event that requires a cahse light (but you don't want one installed all the time). It utilizes RAM suction cups which are REALLY strong and hold things up very well. It plugs into a cigarette light and there is a 13' cord so it'll have no problems reaching.
Ryslegit
SoCal
22 Bronco Badlands Sas
We're rolling out this billet mount setup now for triple @Baja Designs S2s. It will be available exclusivley through our website and Apollo Optics. Roof rack mount, auxiliary mount to the OEM 3rd brake light and spare tire mount brackets are also in development. Working directly with Baja Designs, we're taking light mounting solutions to a whole new level of awesome!
Reviving this thread regarding these. Are there any progress updates on it? I need to change my chase light set up and this may be exactly what I need.
Shrek27
Fullerton CA
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Gen2 Raptor Midtravel / TowRunner F250
Introducing our new Multifunction Hammer Built Multifunction third brake light.
-100% Made in USA,
-100% modular aluminum design
-plug and play harness
-bump stop stabilizer to prevent wobbling and vibration,
-3 made in Austin Texas Fenix quad cannon emergency LEDs in strobing/constant amber chase lights
-3x super bright white reverse lights
-fully adjustable to 40” tires
-ships out the next business day. $699
https://hpbuilt.shop/products/hamme...light-replacement?_pos=1&_sid=bbb3416a6&_ss=r
Ford Bronco What are you using for chase lights? 1EB6439E-BB68-4798-BE9F-49D8D99901DF
Ford Bronco What are you using for chase lights? IMG_4193
Ford Bronco What are you using for chase lights? IMG_4239
helifino16
Ron
Mount Sinai, NY (Long Island)
I recently got complimented on this temporary light set up that I use for 'Follow-Me' lights. Has many flashing sequences and plugs in easily in that rear power port.
Ford Bronco What are you using for chase lights? 1746102348606-ck
When you're done on the trail, pop 'em off and free up the already limited view out the back.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Have a picture and/or video of them in use on your Bronco?
I bought a set of these intended to use them for chase lights. Ended up putting them on the 4-wheeler for plowing snow. They aren't bad lights for the $25 or whatever I spent on them. I keep waffling back and forth on ordering another set for the Bronco to just use temporarily (like you say), or ponying up the money for a new HMTBL style option that is installed once and there permanently.
helifino16
Ron
Unfortunately, no. They just stick to the back window. There's a video on how they blink on Amazon. I will admit that they are a bit muted because of the tint on my WT, but are plenty bright to be seen from behind.
Beach_Bum
Ken
St. Augustine, FL
Did you use the sticky adhesive disks in the suction cups? Or were the suction cups adequate by themselves?
helifino16
Ron
I use the suction cups as it’s really for occasional use. I wasn’t looking for a permanent solution.
