What are these plastic tabs?
bigbendsasquatch
Brett
georgia
2024 big bend sasquatch and 2024 black diamond
This is my wife’s black diamond four door. My two door didn’t have these. What are these little plastic tabs on the window. Are they supposed to have come off? Nevermind my ugly mug
Ford Bronco What are these plastic tabs? IMG_1659
Broncory
Jason
Ga
2023 Bronco 4D SAS
They should come off. Not sure how to remove them though. Mine were already removed when I took delivery
PWillette
Parrie
Maine
Spacers for when the glass was installed, should have been removed at the factory. Wonder if the glass was replaced by the dealer?
Ones I have seen in the past simply turn them 90deg and they should come out.
bigbendsasquatch
bigbendsasquatch
Brett
georgia
I don’t think the dealer replaced glass. It’s on both sides. I figured it was just something they forgot to take off.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
It's probably defective. I'll trade you my non-defective MIC top for your gloss black top and it should resolve your issue :wink:
G1D1UP
J.
Gilbert, AZ
2024 Ford Bronco Raptor
WARNING! DO NOT REMOVE!
It could open a portal or riff in time that leads to all sorts of unpredictable chaos! Like you trading in your Bronco for a pink electric Cyber truck! I'd leave them on as an exclusive FORD OEM mod.
Ford Bronco What are these plastic tabs? 1zgpz3
BroncoChallenger
2024 Bronco
Oh you guys should see the Super Duties. Crawl around one and you'll probably find 4-5 rubber bands on them somewhere. Evidently that's a GAME to the line workers in Kentucky.
CitrusBronco
Everglades
Citrus county, FL
Everglades
I think you ment zip ties on the driveline. The long end hits part of the truck as it spins.
Ducati1098
That's not just a Super Duty thing, it's a Ford thing.
Look at most Ford vehicles and you'll find rubber bands in multiple spots. I think they're used to hold harnesses together before they're assembled on the vehicle. Pretty common.
Matthew
I had to pull mine off recently. Hard to tell from your photo but does your black hard top on the rear driver side not sit even the whole length of rear panel? Mine is currently at the dealership for a plethora of things (panel adjustements, tires with flat spots, door sill dent, hard top fitment) and when inquired about it they told me some fit that way and showed me a few that were similar. I was thinking the rear panel needed adjustment.
Ford Bronco What are these plastic tabs? IMG_0666
RB50
RB50
Chicago Area
2024 Bronco
Those should have been removed during delivery. I had the same issue. Hold the glass with your palm, then use pliers to wiggle them out.
UncleBrad
Brad
2024 Bronco 2-DR Manual
They're supposed to be removed by the dealer during the PDI. You can just pull them out and throw them in the garbage.
Exactly. They are their for reducing shock/vibration during transport. They are meant to be removed.
