What accessory would go here?
Lifeliberty
Moonbeam👀
Columbus, OH
2022 WT -Tried 1/4 " bolts + they seem to fit the accessory mount.Is that what works for mounting accessories [or is a metric bolt needed-1/4" bolt seems like a good fit but have just hand tightened as a test] Looking to mount a GoPro 13 + don't want to ding the threads. Have looked at manual + found no info.
I believe it's 1/4 - 20 bolt. Not metric
Have no expectations and you'll cease to be disappointed
Ford Bronco What accessory would go here? 17561697181601675159278201769442
Jossman
1979 F150,2011 Mustang,2013 F150,2006 HD
Thanks for the verification.
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Just had a pretty irritating realization this morning. The USB ports on the top of the dash don’t connect to Sync. They are nothing but Power. What a huge swing and a miss for Ford.
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
New Bronco owner here.
What accessories use this threaded bung on the center dash? I’m guessing some type of phone holder.
Anything you want to mount there with a 1/4-20 bolt.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
Yeah, it's a bummer. I was considering moving my phone up there, but they're just charge ports, not data ports. They're a lot less useful than they could be. I have to use the two ports down by my shifter to connect devices. I haven't tried a USB hub down there yet to try and expand my device footprint. I have no idea how the sync system would even respond to that.
AZCoyote
Wiley
Phoenix
The ports under the climate control are Sync capable. If you want lossless audio, they are the only game. Seriously annoying.
crzyhawk
Virgina
Yeah, I have both in use at the moment. The older style USB I keep my phone plugged into, and I have a memory stick plugged into the second one for music. I /could/ plug a USB hub down there to get more, but I don't know how sync would react to extra devices. If the answer is "poorly" it might explain why the dash are charge ports rather than data ports.
AZCoyote
Wiley
Phoenix
They thought far enough had to give you away to power your GoPro, but not far enough ahead to understand those ports should be connected directly into the sync system. I’m gonna split the point.
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Ford Bronco What accessory would go here? IMG_5434
Ford Bronco What accessory would go here? IMG_5436
Ford Bronco What accessory would go here? IMG_1233
they didn’t have a cactus grey toy when I made this 😂 but a few pebbles from the wife’s indoor plants and some epoxy and you’re good to go
