What accessory goes between the antenna and side mirror
quickstep192
chas
Maryland
Bronco Black Diamond
I noticed the words “accessory ready” on a plate between the antenna and side view mirror.
I’m curious to know what accessory goes here.
I don’t know what it is, but I feel like I need it!
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
^^^Yep^^^
And the wiring connections are on driver's-side/under hood/by firewall (if you have option). :D
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
If anyone has that black plastic cover from the passenger side, I'd gladly pay shipping to get that part. (mine got scratched and I know many ditch that piece for ditch lights lol). Thanks
CalvinT
Calvin
Phoenix, AZ
helifino16
Ron
Mount Sinai, NY (Long Island)
An example
Ford Bronco What accessory goes between the antenna and side mirror IMG_3445
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Does anyone have a small, less obtrusive light for this spot?
You can bolt almost any light you want there - the brackets are more or less universal.
Many people are doing bigger lights like the look of it, which is fine.
The BluMak3D mount was making the rounds lately for being a good bit less obvious and intrusive, and using a smaller 2” pod
bryan@blumak3d
Bryan
blumak3d.com
93 Cobra, Z4M, K1600GT, R1300 GS
CalvinT
Calvin
Phoenix, AZ
You have to be careful what you mount there. Many people put forward facing lights, but you'll probably get glare back off your hood. I think a ditch light is the only choice that makes sense if you're buying lights to use and not to impress.
DALOLA
Retired
Ohio 🇺🇸
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
Diode Dynamics makes 2", 3", 4" and maybe larger lights that work there in multiple brightness levels. I have 3" square white Diode Dynamics lights mounted with amber backlighting.
