Washer Fluid Low Alarm
RHeinz
Ric
Houston, TX
Had my Bronco into the dealer about a year ago to replace the washer pump.
Now, with no signs of leaking washer fluid under the vehicle, the fluid keeps “disappearing” and I get a ”LOW WASHER FLUID ALARM.”
One of you Ford Service Managers posted the procedure to access the washer fluid reservoir. Can you please repost? Perhaps if it is just something simple I can do it myself.
Stopped at my local dealer yesterday to schedule this repair UNDER THE WARRANTY. The Service Advisor indicated the “Trim Guy” was booked “a week out”. He told me that the vehicle must therefore sit at the Dealer for a week (to hold my place in line…) before it can even be looked at!!!!!!! Bullshit, I’ll just pay my mechanic to fix it…. A sad state of affairs…..
Ducati1098
Windshield Washer Reservoir
Special Tool(s) / General Equipment
Fluid Suction Gun
Fluid Container
Materials
NameSpecification
Motorcraft® Premium Windshield Wash Concentrate with Bitterant
ZC-32-B2
WSS-M14P19-A
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Siphon the windshield washer fluid out.
    1. Open the windshield washer fluid reservoir cap.
    1. Siphon the windshield washer fluid.
      Use the General Equipment: Fluid Suction Gun
      Use the General Equipment: Fluid Container
Ford Bronco {thread} {filename}
  1. Remove the windshield washer fluid reservoir fill neck.
    1. Detach the windshield washer fluid hoses.
    1. Remove the windshield washer fluid reservoir fill neck retainer.
      Torque: 42 lb.in (4.8 Nm)
    1. Remove the windshield washer fluid reservoir retainer.
  1. Remove the fender splash shield.
    Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
  1. Disconnect windshield washer fluid reservoir wiring harness and hoses.
    1. Disconnect the hoses.
      Refer to: Washer Hose Coupling (501-16 Wipers and Washers, General Procedures).
    1. Disconnect the windshield washer fluid reservoir wiring harness.
    1. Unclip and position aside the wiring harness.
    1. Remove the retainer.
    1. Remove the retainer and the windshield washer fluid reservoir.
Installation
  1. NOTICE: Do not operate the washer pump prior to filling the windshield washer reservoir. Failure to follow this instruction may result in premature pump failure.
    To install, reverse the removal procedure.
    Material: Motorcraft® Premium Windshield Wash Concentrate with Bitterant / ZC-32-B2 (WSS-M14P19-A)
RHeinz
RHeinz
Ric
Houston, TX
Thanks!
RHeinz
RHeinz
Ric
Houston, TX
@Ducati1098
I really appreciate you posting. I’m curious as to why every step is a “1.”. No Step 2.’s???
Nice computer generated illustrations. I finally recognized the rear view mirror and realized the “depiction was ”looking” up under the fender from below…. Is the fender liner hard to get off?
Ducati1098
@Ducati1098
For some reason when I copy it out of the workshop manual, it turns everything into a step 1. Not entirely sure why. I attached a PDF of the instructions which should have the correct format.
The fender liner is very easy to remove, just a bunch of plastic push pins and a few small screws.
RHeinz
RHeinz
Ric
Houston, TX
Super!!!
Thank you!
On the schedule for tomorrow morning.
ChrisB351
Shreveport, LA
had windshield replaced? mine did that and they left something undone. as for the dealer experience thats pretty much the norm these days due to lack of parts and technicians.
Squatch
@Ducati1098 - I'd like to add a thank you onto this thread for providing the images and instructions.
I thought I had just one mouse chewed hole and I cut it out and put a split in, then I saw one more, then another, I replaced that whole section of the washer fluid hose, then I finally saw the pattern of a chewed hole about every inch going down into the void... 😂
I'm just hoping I don't have to take the wheel off to comfortably access it.
Ducati1098
No problem. I think you might be able to pull the flare off real quick, then just pull down the top of the fender splash shield for access.
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
I don't know what it in today's plastics, but not only to mice and other vermin go for it, but it drives my cat crazy. Even the UPS shipping label containers have to be locked up...
