Washer fluid leaking
Terry Tonka
Terry
2021 First Edition Bronco, Dodge Durango, Chevy 35
Has anyone else had this problem yet?
Leaks a whole gallon out in 1 day.
How do you get the washer jug out?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, Terry! If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into this washer concern. Thanks!
Terry Tonka
Terry
why do you need dealer info? I bought it at Grapevine Ford, 5 minutes from my house but I will NOT use them ever again. I drive 35 minutes to a different dealer.
Terry Tonka
Terry
VIN # 1FMEE5EPOMLA40587
e30rida
Jay
Miami
'22 Bronco
I also have the washer reservoir leaking. Seems it is another FORD defective part as many people have had the same issue. First car I've ever had that has a WWF leak. I wonder what else is mediocre in this car if they can' get a simple water tank right. Seems removal of the tank itself is a huge PITA. Some have reported taking the fender off is the way to go. Uggghh
Sunday Money
Terry Tool: Did you consider searching the forum before posting? If not, it can have AMAZING results. Not sure how it works, I'm guessing magic.
https://www.bronco6g.com/forum/threads/washer-fluid-low-alarm.98067/post-2293949
Jay: Same deal, just search if you're looking for "what else is mediocre in this car if they can' get a simple water tank right". Also, bimmers have similar issues (I had much more expensive problems with my last BMW than a leaking washer fluid reservoir)
https://www.bronco6g.com/forum/thre...-on-my-2021-first-edition.100450/post-2328137
CarGuy
New Jersey
2023 Ford Bronco
I have a problem where it sporadically needs to re-prime the pump…have to hold it for a minute or so.
