Voiding warranty on rear camera question.
Yes but it’s not a waste gate noise. I have looked into that and it’s clearly an octane ping.
I isolated the waste gate and still the noise is present.
Ok. It’s the metal stem that goes from the actuator to the gate itself that rattles (and seems to stop once it’s warmed up in there and I assume everything expands to fight tighter), so if you mechanically pulled that and it’s not it - then I dunno. That’s all I got
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
The answer to OP’s question is still yes. I doubt anyone here other than me has ever even read a new vehicle warranty.
Ducati1098
No it's not. I would literally warranty a camera concern without any issue whether there was a reinforcement bracket or not as long as the camera itself has not been modified.
Warranty coverage determined by the dealer. So if someone is worried about warranty, they should ask their dealership who will be performing any repairs.
Andrew Bynum
Los Angeles
Im talking about the warranty. The thing OP asked about. I don’t care what you cover when you don’t have to cover it.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Seeing as how the 2 experts are disagreeing, I think the answer is that, while many dealerships might not deny the warranty, they could and would be legally able to.
Ducati1098
Yes, so am I.
Simply installing a tailgate reinforcement doesn’t affect the warranty on the camera.
Ducati1098
Yes, at the end of the day, dealerships can try and deny anything they want. But denying camera warranty because a small 1/4” plate was placed behind the spare tire mount doesn’t make any sense at all lol
If any dealership tried to claim that, you likely don’t want your vehicle serviced there to begin with.
Andrew Bynum
Los Angeles
Ducati1098
You may have missed this part, counsel:
Didn’t miss it. Any reinforcement will obviously mount behind the tire carrier.
But like I said above, simply putting a spacer behind the mount doesn’t affect camera operation at all.
If you start changing the actual factory tire carrier/camera mount to an aftermarket one, or have to modify the camera wiring like @Brian_B previously mentioned, then yes that would obviously no longer be warranty. But 99% of reinforcements don’t require any modifications to the mount or camera.
