Upgrading Bronco fuel tank capacity
gjennings12
Grayson
Houston
F-150
Does anyone know if there will be aftermarket fuel tanks for Broncos available in the near future and also if they can even fit? If not, I'm sure I'd live but the 16 gallon capacity on the 2 door is pretty low given that the mpg is only 17 if you opt for sas package or lower if you lift.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
IMPO. There will likely be a few options, timing is the unknown.
Expectations:
- aftermarket rear bumper w/ tire swing gate + single or dual Jerry can cage.
- rotopax offerings (I’ll skip those based on experience)
- Full on long range tank swap??? Who knows.
I’ll be in the market for a aftermarket rear bumper with a swing gate + jerry can(s). Mostly because that’s familiar territory.
The x-factor is that these offerings will take time because....nobody has a Bronco to develop these products around. So anything that I’d be interested in will not be available quite some time.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Also the AEV or titan tanks are very likely candidates for Bronco
gjennings12
gjennings12
Grayson
Houston
F-150
I saw that Titan tanks are often stored in the bed of pickups. I would not want to sacrifice any of the limited cargo area I have. If something could fit under the truck I would 100% buy.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Hmmm, I version I’m referring to in this context is the competitor to AEV’s ā€œfuel caddyā€. Mounts in between the spare & mounting location for the same spare.
this one (obviously this is for the wrangler)
https://www.aev-conversions.com/product/fuel-caddy/
AcesandEights
Ace!
Oregon
DR650
The answer is no.
There will be auxiliary tanks, separet to the fuel system (think gas cans, Rotopax, plastic tire insert deals) but not bigger aftermarket replacement fuel tanks. Gas and diesel fuel systems are certified completely different and making a different "gas" tank is too much of a pain in the ass. So, there will be auxiliary tanks that are not tied into the fuel system, not in any way connected, but not the tied in auxiliary tanks you see for diesel pick ups.
Daktari
Oliver
I really like this idea, if they come out with one for the Bronco (and why wouldn't they?) I'd buy that immediately. Nicely hidden, no ugly jerry cans hanging around and easy to fill into the built in tank. And when you don't need it, just leave it empty, doesn't add much weight and is almost invisible. 10+ extra gal is a nice range extension. Added to the book mark list my wallet doesn't like :-D
Tricky Dick
Dick
PNW
www.TD-Distributing.com
BackcountryBirds
Virginia (temporarily)
2019 Ram Power Wagon
There are going to be legitimate situations towing a small off-road trailer in the mountains for example where a 2 door squatch bronco range may be under 200 miles. It also has limited space and payload rating to carry extra fuel.
At some point it just becomes an off-road toy and not very realistic to drive to the trail. Alot of the range arguments people make for electric (rightfully so) begin to creep in.
I'm starting the get intrigued about holding out for an all electric bronco or 4XE style hybrid to use as a daily driver for commuting to work and riding around town without paying for gas. Even more so when the government tax incentives and high gas prices. Then supplement with an F150 powerboost (or F250 if Ford drops it in the HD lineup). Use the truck for longer trips and for towing the bronco to the trail and then you can probably plug in the electric bronco at night off the powerboost and have plenty of power to run the trails with all electric.
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Expectations:
I'm curious of your experience with them. I've never had them so I'm in the dark.
I like the Fuel Caddy...slick idea.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Expectations:
This is where it sucks the Australian market won’t be getting a RHD Bronco. A lot of the auxiliary tank options for the Jeep come from Australia.
RBF 1401
Tricia
Tucson
98 Avalon, 95 Dakota
...no ugly jerry cans hanging around...
Ugly? Jerry cans are a thing of beauty!šŸ˜šŸ˜šŸ˜
I'm hoping I can figure out how to carry 1 or 2 cans of gas and 3 or 4 cans of water.😁😁
I saw an old Jeep in traffic with two jerry cans on the hood. I wonder what the weight limit is on the hood. Not a bad place to carry some extra water.šŸ¤”šŸ¤”
Dads_bronze_bronco
There really isn’t much more space for a bigger tank if you never seen the underside before.
Aux tank on the opposite side, possibly rerouting the exhaust pipe a little - the are several for Jeeps and Landrovers out there.
