Upgraded Audio installer having issues
Dawgzz
Jason Johnson
2022 Bronco
They have replaced all speakers, dsp amp and sub. They turned it on to tune said rear pods started to emit ow screech then started to lose voltage from rca’s. Now ordering new access dsp and waiting for their engineering. Should they be looking at something other than dsp? Amp is SMD 5 channel. Any help would be appreciated. Thanks in advance.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Disco all speaker wires at amp. Connect one at time or use ohm meter. You will find offending line or amp is just bad. Possible. Or just use a test speaker at each amp output.
Dawgzz
Jason Johnson
2022 Bronco
They also added a new upgraded battery and desired beginning there as well. I will pass on your suggestion appreciate it.
Dawgzz
Jason Johnson
2022 Bronco
Sorry meant to say they have rewired everything from there back.
I'd say the old adage of "Garbage In Garbage Out" may apply here -- make sure you are getting good inputs from the head unit in the first place, one channel/speaker at a time, isolating one component at a time as you can, and just work your way through it.
Since your shop has already replaced darn near everything they have installed, and even thrown a new battery at it - it looks like they are just throwing parts at it without actually taking the time to troubleshoot it. And while it's not common, it also wouldn't be unheard of for the Bronco to have some crap coming out of the stereo that's just getting pushed on through the rest of the system.
Dawgzz
Jason Johnson
2022 Bronco
I listed the components and a few pictures
Ford Bronco Upgraded Audio installer having issues IMG_4599
Ford Bronco Upgraded Audio installer having issues IMG_4600
Ford Bronco Upgraded Audio installer having issues IMG_4619
Ford Bronco Upgraded Audio installer having issues IMG_4620
Ford Bronco Upgraded Audio installer having issues 6769f92fab61505833b8cd8c
WarthogJr
'21 Bronco Black Diamond
The head unit in the Bronco has to sense resistance in the speaker wires. If it doesn’t, the output will decrease rapidly until it gets to zero. You’ll think you fried your system- at least I did. Having a quality LOC is critical; they aren’t all the same. Contact Audio Control if you think this could be the issue- they helped me a ton.
PNBLWZD
James
CA
Hellcat Challenger, Mbz S550, Mbz GLE63s, Silverado SS
Is it my imagination or has the GOAT dial been relocated forward on the console?
More pics of what that’s all about please
Dawgzz
Jason Johnson
2022 Bronco
It has not been moved, this is where the GOAT mode selector is located in the 2 door with manual transmission.
Ford Bronco Upgraded Audio installer having issues IMG_2233
Ford Bronco Upgraded Audio installer having issues IMG_2230
22Wildtrak
2022 Ford Bronco
I had all kicker speakers and 500 watt amp and 6 1/2 rear speaker pods and a 12 inch kicker box and all works perfect and sound awesome
HMF-Jody
Jody
Suwanee, GA
2024 Bronco
I had a similar issue in a previous GM vehicle and we ended up having to change out the Axxess interface then used a zen A2B interface and had same issues, and last used a audiotech fischer Helix DSP. its pricey but fixed all the issues I had. I was running 3 amplifiers, 3 JL 10w6, Focal 3 way front stage, Focal 3 way rear doors.
https://www.audiotec-fischer.de/en/helix/processors/dsp-ultra
Big K
Kevin
ohio
[/QUOTE
I also had problems with Axxess DSP, emitted a strange rumble from my sub. Replaced with Metra PAC. Problem gone!
Dawgzz
Jason Johnson
2022 Bronco
I want to thank everyone for the input, the dsp was the issue. It was
Ford Bronco Upgraded Audio installer having issues IMG_4682
Ford Bronco Upgraded Audio installer having issues IMG_4680
Ford Bronco Upgraded Audio installer having issues IMG_4679
Ford Bronco Upgraded Audio installer having issues IMG_4678
Ford Bronco Upgraded Audio installer having issues IMG_4675
Ford Bronco Upgraded Audio installer having issues IMG_4676
Ford Bronco Upgraded Audio installer having issues IMG_4674
replaced the install has been completed
WeyanGe
Teon
Challenger SRT Hellcat
I had similar noise problems until I switched to a high-quality solderless rca cable system. It made a noticeable difference by cutting out the interference I was getting from my amp and HU. The install was way easier too since I didn't have to mess with soldering or splicing anything behind the dash. Might be worth checking if that's part of your issue.
