*UPDATE - RESOLVED* Anyone else have starter issues? (Multiple failures to start)
AK SNO RIDER
Ty
Alaska
Having issues with the Bronco not starting. Press the start button and get a CLICK from underneath but no action from the starter. Press the button over and over and eventually it'll fire right up like nothing was ever wrong.
Have it scheduled to go to the dealer, but it's highly intermittent and will certainly be impossible for them to replicate without some real luck.
Anyone experience this and find the culprit?
-UPDATE-
I took another look at the starter this morning, and the nut for the power is clearly backed off and stuck sideways. It's not loose, and wouldn't budge in either direction, so I'm not dealing with it myself. Could I? Sure, but that's what warranty is for. It's at the dealer now.
Ford Bronco *UPDATE - RESOLVED* Anyone else have starter issues? (Multiple failures to start) 20221005_112248
Xrayphoton1
Houston
Camaro
Record a video on your phone too and get their email
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
Definitely check battery terminals, cables and grounds. Something is loose.
Battery cables are good...certainly acts like it's a bad connection somewhere, yet eventually starts without touching or jiggling anything at all. I've checked my fuse box connections in the past but not recently.
I'm not gonna touch anything else until the dealer looks at it just because I want the best possible chance of them being able to replicate it. Got the extended warranty this time for a reason 😂
But if anyone else has had a similar failure could help them diagnose.
Good call, if it does it again before next Friday's appt I will.
VIRUS
D
Wisconsin
Truck, car, feet
On two separate occasions a few days apart, I've had to push the button several times before it would start. One time it took about 10 tries before it started.
Did not notice a click either time. Haven't taken it in. Will wait for it to totally fail. Pretty sure if I took it in now, service wouldn't be able to duplicate the issue.
Tilzbow
NV
GM Sierra Diesel Pick Up
Mine does this occasionally but only takes one try. When it happens I’m usually in a hurry or being lazy nd might night be pressing the brake pedal hard and/or long enough to complete the start cycle.
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
Fuel pump failing?
If that were the case it should at least try to crank, but it doesn't.
Did it again this morning. Battery read 12.3V so not dead, confirmed it with a multimeter. Just for kicks I put a jump pack to it and Bronco immediately fired up. Not sure what's going on.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there! I can look into your Bronco’s concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
  • Haha
Reactions: Cat
Blaven
Pennsylvania
Very strange indeed. Hopefully the dealer can find out what's going on with it.
PWillette
Parrie
Maine
Not dead at 12.3 but relatively low for some electrics. The jump pack kinda proved voltage maybe a bit low. If the starter is clicking it's obviously trying to spin...possibly just not enough voltage to overcome the high engine compression...a few clicks of the ignition switch probably just enough to move flywheel past a high compression point to eventually spin. What is your voltage reading while running?
BWarned
Brad
Fort Wayne
21 Wildtrack
I had this issue and they did replace the starter and the battery. 8k miles later it’s back but also shows up with the auto start/stop not restarting the engine. It’s been at the dealer for a month and they still haven’t figured it out.
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
Was showing 14.8V on the way in to work this morning so the alternator is doing... something.
AK SNO RIDER
AK SNO RIDER
Ty
Alaska
Yikes, that's concerning. So far it hasn't failed to auto-restart; hope it stays that way.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Usually if they make the "click" sound, but don't turn it's a starter motor. The click is the pull in solenoid forcing the gear into the flywheel. The pull in also completes the circuit to the motor armature itself. Sometimes an armature can have a "bad spot" and if it just happened to stop on that bad spot it doesn't want to spin the next time. We usually diagnose these by having someone hold the key and tapping on the starter a few times w/a small hammer. It's possible you shook the vehicle enough when you popped the hood and installed the jump box to free the starter up. My money would be on a slightly flaky starter motor!
