Anyone else having too many issues?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I’m just gonna pull the dash out and figure out where it’s coming from. I’m gonna add some ambient lighting while I have it off anyway. It gives me an excuse to add lights.
There ya go! Still see if you can get some help diagnosing it, once you have it apart I don't imagine it'll be easy to find if you can't actually run it. Good luck.
Ant0ni0S
Ant0ni0S
Antonio
2022 Ford Bronco Wildtrak
Thanks
BlueBronco
DFW
I actually fixed a lot of my issues using forscan
What "issues" did you "fix" using FORScan? All that program does is allow you to enable/disable features and change settings within existing parameters. And read DTC's, but clearing codes is not fixing a problem.
While I am all for fixing stuff yourself, that has bad idea written all over it.
Ant0ni0S
Ant0ni0S
Antonio
I work on cars all the time so I am good pulling the dash out. Also my screen has all gibberish all over it so I took it to ford and they said the tech is on vacation so they will call me. After a month of waiting, I found a thread on here that told me how to fix it from forscan. It worked.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Disagree. I was able to get dashboard blackout problem resolved from this forum because they reached out. New cluster replaced last year.
Hi...
My Bronco (2022 WildTrak) is starting to do weird things, like the dashboard display is black, or, it won't recognize the key after remote start.
Can you describe your symptoms?
Thanx.
